Is there a website that will tell me how much the toll is going to cost me when given my route?
I was looking at a route from WI to NJ that would take me on the Indiana and Ohio toll roads.
Going through Indy is only 70 miles longer. If the truck operates at .90 a mile, that would be $63 and a hour of my time.
I'm trying to lower the trucks expenses as much as possible even if it takes a little bit of my time.
Cost of Toll Roads
Discussion in 'Experienced Truckers' Advice' started by Blind Driver, Jan 30, 2013.
Page 1 of 3
i am not sure where you ran your miles but i have it at 130 extra miles from chicago to youngstown, compared to chicago to indy and then youngstown.
I haven't been able to find one for trucks. I have to research each agency individually along my route.
Here is one for Indiana
http://www.in.gov/ifa/files/ITRCC_Toll_Rates.pdf
Here is one for Ohio
http://www.ohioturnpike.org/travelers/fares/fare_calculator_axle_class_12/
as far as ohio goes, first company i worked for did not allow ohio tpke...required us to run 20 and 2 that are parallel just to the north. not too bad, and free.
A lot of the States with Toll roads will have a Site that will tell you how much they cost.
Tolls are a 100% write off as far as truck expenses go, so why avoid the shortest route.
Where in jerzy--to go thru Indy and add only 30 miles than probably requires runnin the pa pike which has really goten out of hand--personally I run 30 across in/oh then 71n to 76e back on 80 little more time better at nite--mileage diff is negligible and @75k or above saves somewhere around 70bucks
Just my $02 -
Page 1 of 3
