Could these frigid temps cause a stop engine light and shutdown?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gix1k, Jan 15, 2025.
  1. Gix1k
    Gix1k Medium Load Member
    373
    586
    Dec 11, 2019
    Truck hasn’t been started since around Thanksgiving. I went over today, turned on the power, it started right up. I jumped out and into my pickup while it warmed up. Within about 4 mins I heard it shutdown. I got back in and saw both CELs and red stop light. I cycled the key, it started right back up again and I sat there to see what the dash did and with a min the red stop light came on, I shut it off. It’s been roughly 15 degrees for weeks or more. This wasn’t an issue when I parked it months ago.
  3. DUNE-T
    DUNE-T Road Train Member
    7,020
    17,079
    May 10, 2015
    Detroit, MI
    Well, what's the code for shutdown? It has to tell you why it's turning off
  4. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    I bet it's low coolant level. Our trucks always find coolant leaks when it starts getting cold. Doesn't take much for it to trip the level sensor.
    Feedman, '88K100, Bean Jr. and 7 others Thank this.
  5. Arctic_fox
    4,374
    23,850
    Sep 16, 2016
    Could be gelled filters or fuel. If you used howes and just dumped it in then left or went too light on it that can cause issues. Same if you had bio diesel or the dudes delivering didnt treat the fuel correctly.
    Ive had an instance where my fuel partially gelled and the truck started, ran for 30 or 40 mins then died going down the road.
  6. austinmike
    126,651
  7. Gix1k
    373
    586
    Dec 11, 2019
    It’s not throwing a code. I have a system connected that tells me. Well, it’s throwing a code for DEF but it has been. That’s what prompted me to go start it today. I was taking it to Freightliner to get that fixed before the season starts.
    austinmike Thanks this.
  8. Gix1k
    373
    586
    Dec 11, 2019
    I poured half a bottle of treatment in the tank back in Nov. I won’t try to start it again until it gets to 30s/40s
  9. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
    I'm gonna echo the others and go with low coolant
  10. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    check all your fluid levels, mostly coolant.
    If the coolest it's been is 15 degrees I doubt you are gelled but for future reference id double the amount you put in and let the truck run for an hour or more after putting it in so it can get mixed in..
  11. Ridgeline
    22,636
    120,604
    Fuel is gelled, happens a lot. The heat from the engine seems to help soak the fuel system and that’s why it will shut down.
    Feedman, austinmike and Gix1k Thank this.
