Could these frigid temps cause a stop engine light and shutdown?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gix1k, Jan 15, 2025.
  1. Gix1k
    Gix1k Medium Load Member
    373
    586
    Dec 11, 2019
    Yeah I didn’t do that. Thanks for advice.
    austinmike Thanks this.
  3. Gix1k
    373
    586
    Dec 11, 2019
    Good to know. Truck hasn’t moved. Had me wondering what could have happened.
  4. austinmike
    126,958
    I used to use alot of that fuel treatment stuff. Like a whole bottle in each tank. Had gelled fuel one morning. Some jacksss had unplugged my hot block heater and plugged in a dead one. :mad:
    Ten below zero. So much fun.
  5. '88K100
    '88K100 Road Train Member
    1,412
    3,262
    Aug 23, 2020
    On some it can be faulty low coolant sensor,,if you unplug that sensor it will not shut down…found this with Cummins X15
    Speedy356 Thanks this.
  6. Gix1k
    373
    586
    Dec 11, 2019
    I was blue to get over to truck today. I poured some diesel 911 in in case I had a gel situation. Then I looked at the coolant reservoir and this was it. It is rather low. Could this be a cause?
    https://imgur.com/a/yrcN9vy
  7. Ridgeline
    22,640
    120,728
    That's not low.
  8. Gix1k
    373
    586
    Dec 11, 2019
    It was actually…a whole gallon low. I filled it and no more lights on the dash. It’s all odd because it wasn’t low when I parked it in Oct
  9. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    cold weather brings out leaks. usually small ones. metal expands or contracts with temperature change. fluid as well
  10. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    also you really should pull the hood open everyday and check fluids. But especially if the truck has been sitting for a long time check your fluids. never know what could happen. oil pan could be empty for various reasons
  11. Arctic_fox
    4,380
    23,931
    Sep 16, 2016
    That actully happened to my ram once. Rodent had chewed a some wires that had fallen and shorted against the pan and melted a small hole in it while it was sitting. Lucky it didnt catch fire. But a vehicle sitting for even a few weeks can have issues.
    lester Thanks this.
