Couple of Questions for Line 4 logging
Discussion in 'Questions From New Drivers' started by d007, Apr 9, 2013.
  1. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    I run interstate in a truck weighing just under 26,000. A lot of my day is spent driving but I stop anywhere between four and ten times to unload cargo. Usually these are stops less than fifteen minutes. Right now I have been drawing a line down from line 3 to line 4 and flagging the city and state I am in along with the number of minutes I was actually stopped.
    Like -- Fremont, MI 5 Mins --- Is that correct for a flag?
    Also, I punch a clock and run less than 12 hours, do I still fill out the side of the log with the daily hours worked and my countdown from 60 on it?
    I'm self taught and so far I think I have the gist of it from reading the reg books but I've run all local under 100 air miles rule before and the little things like this are confusing.
  3. DGStrong71
    DGStrong71 Road Train Member
    1,279
    407
    Feb 22, 2013
    70° west
    I'm not real sure but I think you can stay on line 4 even while driving since you are running local.
  4. ridinbikes247
    ridinbikes247 Bobtail Member
    27
    Mar 20, 2013
    High Point N,C
    if you stay within 100 mile radius of your terminal you dont need log books. At least thats for N,C. I drove for 12 years in straight trucks, and even our local tractor drivers didnt keep logs
  5. ridinbikes247
    27
    Mar 20, 2013
    High Point N,C
    If you dont have a CDL you can go within 150 miles
  6. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    I am usually in two or three states a day and I run a radius of 250 miles.
  7. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    The 100 miles is straight line miles from your terminal. If your under that (100 air miles) and return to it (the home terminal) at the end of each duty shift. You may not need to log your time.
  8. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    I've been running from Toledo, OH to Muskegon, MI a lot lately. Thats like 200 miles one way.
  9. zmpart
    zmpart Light Load Member
    135
    92
    Nov 27, 2010
    as far as the flagging goes that is right, if it is 7 mins or less, more then 8 you should show 15 mins on line 4
