Couples training
Discussion in 'Questions From New Drivers' started by upngone2010, Mar 21, 2011.
  1. upngone2010
    upngone2010 Bobtail Member
    My wife and I are thinking about trucking as an option right now but we want to be able to stay together through out the training process. Anyone know any companies that do couples training ?
  3. mayoman69
    mayoman69 Light Load Member
    115
    23
    Feb 28, 2011
    Old Saybrook, Ct
    I went to school with a couple and decided to work for Reohl as a team. But they have to do the training seperatly on two different trucks. I'm not sure if that is a standard throughout but you should call around and check.
  4. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    2 trainees with 1 trainer in 1 truck would probably not be very efficient, or at least double the training time since each person has to cut their time in half, assuming the trainer is in the passenger seat the whole time.
  5. upngone2010
    Thanks...I'll call around a bit..found an older post that says Central Reefer does couples.
  6. Lady K
    Lady K Road Train Member
    Yes - CRS (Central Ref) does train couples together - there was a couple that went through the same time my husband did. Now my husband and I did ours separetly - but he was unemployed and I was still employed - so he went first and I stayed to tie up loose ends... either way works, but the time separated SUCKED!!
