CPAP & Inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Winger, Apr 5, 2013.
  1. Winger
    Winger Light Load Member
    93
    39
    Dec 20, 2009
    Fl
    Can I run my cpap on a regular inverter or should I run it on a pure sine inverter
    thanks
  3. cookiebeta
    cookiebeta Bobtail Member
    11
    Mar 15, 2013
    Have you checked the info. on the maker's website? I don't know the answer, but I'd like to know as well since I have one and will need it OTR. I was just planning on getting a 12v converter and plugging it into the cab's outlet. Let me know if I'm totally off base.
  4. dptrucker
    dptrucker Road Train Member
    4,681
    3,197
    May 14, 2012
    adelanto,ca.
    company you go with will install the inverter for you. you"ll just have to get the enverter.
  5. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    12v power cord works well. Contact the maker of your machine.
    cookiebeta Thanks this.
  6. mickeyrat
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    it will run on either but in my opinion go with pure sine. then if you dont idle then you will get straight power without flucuation in juice. Stay away from those cheap ones sold at truck stops for use with cpap.
    You can also get a 12v power cord for your machine, they work well.
  7. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    I second this. Many of the machines will run on AC or DC power. You will not run the batteries down as fast if you can plug the machine directly into the 12V plug. The inverter uses power converting it.
  8. Winger
    93
    39
    Dec 20, 2009
    Fl
    The CPAP unit that I have will only run on 110 volts.
    Please read my original post as to the question that I had asked!!!!
  9. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    you failed to mention in the original post that your machine was a 110 volt machine only. complete information always helps when asking for others opinions.
  10. MoGooder
    MoGooder Light Load Member
    160
    57
    Mar 15, 2013
    Kenosha, WI
    Turtle posted in Expediters Online that a pure sine inverter is needed for a CPAP machine. If I remember correctly it has to do with ruining the humidifier. Their site is set up the same as this one. Go there and search CPAP.
  11. Winger
    93
    39
    Dec 20, 2009
    Fl
    I had no idea that these machine will run either way, but I had asked a specific question!!!!
