CR England Driving backing evaluations
Discussion in 'CR England' started by Perri-Lee, Nov 29, 2011.
  1. Perri-Lee
    Perri-Lee Bobtail Member
    34
    Aug 27, 2011
    Lexington SC
    How difficult is CR Englands driving and backing evaluations on their refresher program in Indiana? Just need to know if anyone has went through it recently. any stories helpful and appreciated. thanks
  3. MysticHZ
    MysticHZ Road Train Member
    5,877
    5,682
    May 28, 2010
    If it's anything like Mira Loma, they laid out cones for you to follow for your set up, pull up as far as you want and then a basic straight back ... All you had to do was make sure you didn't hit a cone.
  4. Perri-Lee
    34
    Aug 27, 2011
    Lexington SC
    what do you mean cones to follow for set up. plz explain if u will
  5. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    He/she means you pull up to the first cone and make a hard right, then get to the second one and make a hard left and so on. When you get to Burns Harbor walk the course so you can see what you need to do.
    Try and watch someone else do it and see what works and doesn't work. Good luck and just relax, CRE needs you to pass so they can get you into a brand new lease truck (truck # starting with 90XXX).
  6. MysticHZ
    5,877
    5,682
    May 28, 2010
    It means if you are breathing and can hold the steering wheel, you can pass the test ...
    Dewey120 Thanks this.
