Crazy markup on parts
Discussion in 'Ask An Owner Operator' started by kay_ray, Jul 31, 2024.
  1. Rideandrepair
    17,333
    56,244
    Aug 8, 2015
    All the Dealerships are Independent franchises. They all have their territories. Doesn’t matter Engine brand dealer or Truck brand dealer. I had the worst experience at Cat of Michigan. They work mostly on Construction equipment. Thought I was going to the best Cat shop. They broke teeth off the bull gear and cracked the timing cover. Found the broken teeth after I took it back leaking oil. Original job was $2000 to rebuild my fuel pump. Still had to buy an upgrade fuel temp sensor kit and install myself, after it derated 300 miles from home. 35 mph all the way. I had specifically told them to change the original internal sensor. Apparently they didn’t know anything about it. That was my last dealing with Cat. Bought a Detroit.
  3. Arctic_fox
    4,056
    21,070
    Sep 16, 2016
    Pretty much this. I take my pete to the same dealer every time. Plus i have an accoint there so i get the fleet pricing ontop of a decent discount for being a regular and doing 100% of my service there.
    For refrence lemme see if i can find them...ah yes had to do my oil change on the road with my own filters at a TA since i couldnt be back before i went WAY over my miles. $534.99 before tax for 11 gallons of T4 rotella 15W-40 the labor and service. Filters were 305.85 from pete. And oil sample kit was $25. Or around $866 bucks and that is pretty much in line with every road place i hit nowadays.
    My oil change at pete, exact same service same filters $630.80 without tax for fluid top off, filters, 11 gallons t4 15W40 rotella, general inspection, new wipers, truck and 5th wheel grease, tires aired up, general once over and included oil sample. Less if i bring my own oil which i do as often as not.
    My at home cost even with bulk buys is around $590 if i pay to dispose of the oil. $515 if i just throw it in the oil heater.
    Most small shops or chains you go to exactly once or arent a discount member of are going to charge you full price. If you have a relasionship with the shop they usually give you much lower prices since it keeps you coming back and they make much more money off you long term then just an expensive once and done job will.
  4. kay_ray
    kay_ray Medium Load Member
    486
    1,206
    Jun 6, 2019
    You probably have a decent/honest service manager working there. The most stealerships i been to try to jack pricing up on parts or jack the hours up by almost double.i dont even get warranty work done. If something goes bad i order it online ship it overnight and Change it the next day and i am rolling Vs Waiting for them to check the problem and go back and forth with paccar ordering the parts and then repairing it takes a week minimum. Oil changes usually cost me around $290 with oil and fleet gaurd filters and 45 mins tops. I dispose off at auto stores so thats usually free .how are you spensing 590 doing your own oil change?
    Arctic_fox, Siinman and Rideandrepair Thank this.
  5. Rideandrepair
    17,333
    56,244
    Aug 8, 2015
    Expensive filters.
  6. Arctic_fox
    4,056
    21,070
    Sep 16, 2016
    T4 shell rotella 15w40 is around $85 per 5 gallon bucket where i live or i can get a 55 gallon drum around $980. 11 gallons at around $17 a gallon average $190 filters are what get me. The OEM kit for a MX is around $305 with the davco fuel filter as well. Oil sample $25
    Around $510-525 depending if i get anything on sale. I live in the middle of bum#### nowhere so i gotta pay around $75 to get rid of 11 gallons of oil if my heater is full.
    Yes i can get the filters cheaper online or use aftermarket. But the MX filters are so expensive that your as likely to get chinese counterfits that destroy your engine as not. So i dont play games and just bite the markup and get them from a pete dealer. That and MX engines are picky as #### and the aftermarket filters as as likely as not to cause issues even if they are "good" ones.
    Siinman Thanks this.
  7. kay_ray
    486
    1,206
    Jun 6, 2019
    Ah wow thanks for reminding me to never buy mx. Are those filters made with gold or give you extended oil change intervals ?. I use delvac for x15 cost me 62$ at walmart per 5 gal comes upto $148 for oil and 140 for all 3 fleet gaurd filters.
    W923, Arctic_fox and Siinman Thank this.
  8. Arctic_fox
    4,056
    21,070
    Sep 16, 2016
    Its a pete. They add a zero to everything just because they can lol. And technically you can go 50 to 65k between changes......but.....i do them at 15k just because im using the severe duty cycle from my manual.
    That and if i can get 15k out of a fuel filter without it clogging, then its a #### holiday miracle. Usually they turn jet black and get goopy after 10k or so and start to throw fuel pressure derates at me. Less if i use a lot of bio diesel. So i tend to not trust my oil filters to lsst a lot longer. As for shell my whole family has used it for 3 generations. I do too because reasons. That and with 1 million miles even if other stuff is cheaper.....i dont want to screw with the chemistry inside the engine.
    W923 and Siinman Thank this.
  9. 50WT
    50WT Road Train Member
    2,268
    20,105
    Dec 26, 2015
    The markup in HVAC is crazy. My son is a manager at a HVAC supplier. He handles the commercial side of the business but he can sale any of it. Got a buddy of his to install a new unit for my home. With the deal from my son and the buddy doing the work for a cash deal it cost me about a third of what the going price was.
    TexasRiverRat and Siinman Thank this.
  10. The one california kid
    The one california kid Medium Load Member
    545
    918
    Oct 31, 2023
    Before trucking I used to work in an auto parts warehouse. Working in the warehouse and receiving the parts and posting them on the computer, I was able to see what the company paid for the parts and then what they did them for at the counter. The markup on most everything was 50% more than what they paid for it, and some items the markup was about 70% more! And this was back in 1986. The manufacturers are trying to make it to where the common working man can't even work on his own vehicles and will have to take it to a shop or dealer to get fixed. That is their end game! And it's B.S.!!
    TheLoadOut Thanks this.
  11. Short Fuse EOD
    2,774
    8,667
    Jul 29, 2015
    Midwest
    For what it’s worth, I noticed Peterbilt Lincoln, Nebraska seems to be cheaper than most dealerships out there on parts.
