Crete, Shafer and Hunt. All the same?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by southtruck, Jan 26, 2016.
  1. southtruck
    southtruck Light Load Member
    160
    97
    Sep 14, 2014
    Flaw dah
    been researching Crete and found that Shafer and Hunt are all under the same umbrella. Even use the same recruiting website minus the logo header. Are there differences between the three?
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Yes. Crete, red truck. Shafer, blue truck. Hunt, white truck. :D
    southtruck Thanks this.
  4. southtruck
    160
    97
    Sep 14, 2014
    Flaw dah
    Thanks SS, But still wondering maybe differnet loads, crete looks to be dry van, Hunt looks flatbed, Im thinking maybe Shafer is pulling reefer. Or am I wrong in deducing this based on the logo pics on the recruiting pages
  5. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    No you are right. That is how they are set up separate divisions
  6. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    Hunt has more of a maroon truck
    bigkev1115 Thanks this.
  7. brian991219
    brian991219 Road Train Member
    2,954
    5,946
    Aug 10, 2013
    Lords Valley, PA
    Crete and Shaffer use their drivers and equipment interchangeably, meaning just because you hire on as a "Crete" driver you will be trained in refer operations and expected to haul refer loads as needed, same for "Shaffer" drivers being expected to haul dry van. They do not interchange drivers or equipment with the Hunt guys, they are flatbed only. The only place Hunt interacts with Crete or Shaffer is in the back office and at he maintenance shops, which are run under the Acklie Maintenance division.
    Crete and Shaffer trucks are identical except the paint color, they even run the same DOT/MC numbers for the last decade or so, the Hunt trucks are spec'd to pull flatbed and run under different numbers.
  8. bowlwinkle
    bowlwinkle Heavy Load Member
    824
    704
    Aug 27, 2008
    Ankeny, IA
    I've been here at Crete for over 7 years, and have only pulled one Shaffer load. You aren't interchanged. The only one I did do, I did so I wouldn't sit for the weekend to get a load.
    Onadetour Thanks this.
  9. brian991219
    2,954
    5,946
    Aug 10, 2013
    Lords Valley, PA
    Looks like you've been lucky, a few of my friends on the Crete side pull more refer than dry van. I was with them for less than 2 months many years ago and although I was hired for Crete I did my orientation at Shaffer in Mechanicsburg and had a blue Shaffer truck but pulled mostly dry vans, only did 2 refer loads.
  10. MidWest_MacDaddy
    11,169
    18,799
    Feb 21, 2015
    South Carolina
    A very patriot group I would say.
    PhillipFlanders Thanks this.
