Crossing state lines 100 mile exemption
Discussion in 'Questions From New Drivers' started by zaptear, Apr 6, 2012.
  1. zaptear
    zaptear Medium Load Member
    502
    171
    Nov 30, 2010
    vermont
    I have been told that I need to fill out a logbook if I crossed state lines but when I go to the Department of Transportation's website and read the rule there is nothing there stating that when I crossed the line that I need to fill the logbook I operate within a 100 air mile radius at one point I am at 95 air miles but still within the 100 should I be filling out logbook
    bbechtel16 Thanks this.
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Some areas have an "exemption" about figuring the difference between "INTERSTATE" and "INTRASTATE" deliveries/freight, and the use of the 100 mile rule.
    CA looks at any crossing of state boundary as INTERSTATE and with that configuration, a log is required. Your local LEO would be a better way to get the answer you are looking for.
  4. rightlane4trucking
    rightlane4trucking Light Load Member
    124
    79
    Jun 5, 2010
    Mount Shasta, California
    The 100 air-mile exemption is contained in federal regulations (49CFR395.1(e)). Crossing a state line (interstate commerce) does not cause you to lose the exemption.
  5. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I see nothing in the exemption regarding crossing of state lines.
    Also look at the FMCSA Interstate Truck Driver's Guide to Hours of Service on page 8. Keep in mind that you have 12 hours to return to the reporting location from the time that you leave.
  6. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    Keep in mind, like any comparison of Fed v local/State ordinance....the local/State can be more strict but not less strict.
    In CA....any freight that "originated from, or is destined to" another State, is considered INTERSTATE. And the driver of that freight is now under INTERSTATE regulations and a log is required. The exception comes in if the freight is received and off loaded from the INTERSTATE trailer/container and loaded onto a local delivery unit.
  7. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Link the regulation for this please, as it applies to logbook requirements.
  8. TheRoadWarrior
    TheRoadWarrior rocking-n-rollin again
    1,058
    3,154
    Dec 6, 2011
    South West
    Otter is Right on this.... If your pulling a load out of california say to arizona or nevada they concider it Interstate due to the Commerce Rule. Now i do believe that if its from their own warehoue with their own product that might exempt them as long as they stay with in the 100 mile radius.. Same applies to racers if you cross state lines to race and your racing for money then its concidered Commerce and you are subjected to Interstate Laws...But the best way is to check with the local DOT...
  9. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    What's 'right' is what's written in the green book. I don't see any of this in there.
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    I wish I could find the reg in the CA codes...what I know is from experience when I got a citation from the Livermore scale for exactly that....running Interstate freight without the log, since the freight originated from, and was being transported on the same "carrying unit" as where it originated from.
    CA codes are a nightmare to find specific "explanations" without knowing the "key words" to bring it forward.
  11. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Interstate = Federal regulations = Green book = 100 air mile exemption. If you're running Interstate freight, the FMCSA regulations and exemptions from logging apply.
    rightlane4trucking Thanks this.
