Cruise control and Engine brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Doubletrouble1517, Apr 3, 2022.
  1. Doubletrouble1517
    Doubletrouble1517 Bobtail Member
    I have 2017 Western Star 4900 with Cummins engine. Cruise and engine brake stopped working. ECM says clutch is depressed. Where is the clutch sensor or switch located.
  3. bjytech
    bjytech Light Load Member
    242
    221
    Nov 9, 2013
    Clutch switch is right under the lower dash kick panel on the clutch pedal.
  4. Doubletrouble1517
    Changed the clutch switch. Cruise and engine brake still not working. Do you have any other ideas what the problem could be?
  5. AModelCat
    159,543
    Switch adjusted properly? Should hear the microswitch click when the pedal returns.
    If switch is adjusted, check the wiring.
