cruise control problem
Discussion in 'Prime' started by kidnya, Sep 22, 2013.
  1. kidnya
    kidnya Bobtail Member
    40
    8
    Mar 8, 2013
    Has anyone else ever had a problem with the cruise control where you can set it? sometimes if I shut the truck off and let it sit for 5 minutes, it'll reset, and sometimes it won't
  3. HORIZON2819
    HORIZON2819 Bobtail Member
    48
    14
    Nov 26, 2012
    Toronto,ON
    Yes, whenever you shut the truck off. It ask for reset.. Dont know about newer trucks though
  4. Pilgrim007
    Pilgrim007 Light Load Member
    125
    80
    Sep 9, 2013
    Once set all cruise controls, will return to the selected setting. You have to activate the switch and turn it off and on. But once the vehicle is running it will reactivate once you reach that speed it was set at.
    I never use a CC since I had one stick on me, and the only way to stop the vehicle was slam it in neutral and brake. I continued after disconnecting it.
  5. jdsouza
    jdsouza Heavy Load Member
    750
    48
    Dec 18, 2009
    Port Orchard, Wa
    try step on brakes 2-3 times then you should be able to set the cruise
  6. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Yep... the system needs a brake application to reset.
  7. kidnya
    40
    8
    Mar 8, 2013
    that kind of makes sense, but I've stopped on the side of the road and shut the truck off for 5 minutesnd it still didn't work .....so, I don't know
  8. tirednaz
    tirednaz Heavy Load Member
    838
    430
    Oct 4, 2011
    Arizona
    My 08 Columbia will do that. Cruse Control is working fine make a quick stop and it will not set. I have to stop again and shut the truck down, then it will come back on. I have asked the dealer about it but they want to hook it up and that's money.
  9. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    What are you driving?
  10. Highway101
    Highway101 Road Train Member
    1,145
    693
    Sep 19, 2011
    Fallon, Nevada
    Yeah, my 2013 Condo would do it also, as well as the 2010 Light weight I had previously. Honestly I think it had more to do with the on guard system, I had them both in several times but no one could ever find the problem. Most of the time, after about an hour running down the road using the pedal it would seem to start working just fine. The reason I feel it was the On-guard system is because it was 2 totally different trucks, about the only thing the same in them was the on-guard system.
    tirednaz Thanks this.
  11. tirednaz
    838
    430
    Oct 4, 2011
    Arizona
    Yep that's the same issue I have. Although lately it hasn't reset just driving, I've had to stop to get it to reset.
