Cruise not working
Discussion in 'Kenworth Forum' started by kevtowe, Sep 15, 2012.
  1. kevtowe
    kevtowe Bobtail Member
    2005 T 600 Cruise not working . Jakes work as does everything else . Which fuse is it ? Cruise not identified on my panel diagram on reverse of cover . Any suggestions ? ?
  3. rollin coal
    rollin coal Road Train Member
    13,267
    26,719
    Mar 29, 2008
    TN
    Start pulling and looking.. Your switch in the dash may be worn out also, they cost about $30..
  4. jsalazar
    jsalazar Bobtail Member
    Check if the clutch switch is released and that the cruise control switch is getting juice, might be a dash switch problem.
  5. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    Lay open the panel with the tank pressure, rear temps, etc and look at the aluminum air block on the firewall. There should be 2 round 2 post pressure switches. One cuts off the cruise when the brakes or hand valve is applied. They work off ground. Hook test light clip to battery power and touch both. Should light up if brakes are not applied and go out on one side when they are.
    Slick900 Thanks this.
  6. CatPowerC15
    347
    90
    Feb 18, 2010
    Siler City, NC
    If that's your problem they are very hard to remove simply because getting a 9/16 wrench in is impossible. Take a china one and bend it works pretty well
  7. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Make sure clutch pedal all way up mine was acting wacko and clutch was sticking just short of all way up
  8. CatPowerC15
    347
    90
    Feb 18, 2010
    Siler City, NC
    Possibly, but he said the Jake was working fine....
  9. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    Sears sells little stubby combination wrenches.....I used that and a small adjustable wrench.
    it was a PAIN IN THE YOU KNOW WHAT.
  10. brandyb32068
    brandyb32068 Bobtail Member
    where are the switches actually located? Just purchased 06 kenworth t600 and have the same problem.
  11. T6_htx
    T6_htx Bobtail Member
    So are there supposed to be wires going to both bulbs? I have the same problem but onlybhave wires going to the bottom bulb
