CSA 2010 why it needs ending
Discussion in 'Trucking Industry Regulations' started by revelation1911, Apr 15, 2012.
  1. revelation1911
    revelation1911 Heavy Load Member
    923
    308
    Dec 25, 2011
    Moody Alabama
    As the head of the Anti CSA 2010 group I will post some of my
    reasoning behind why I think it's so bad.
    There is no real means to address the actual validity of information posted.
    There is no accontabilty of law enforcement in this, they do pretty much as they feel like a bunch of Maruaders.
    There is no real means of challanging data with any type of legal proceeding if you're not cited and even if you are it's pretty much uphill.
    Information is enterd even if you contest the violation, before any due process is done.
    You are presented as guilty even before being found so.
    There is no inclusion of acts of god for reasoning not to be cited or violation noted.
    They use the faulty data to profile trucks going down the road.
    They want to impose penaties on carriers, but not the enforcers when found doing wrong.
    You can be cited/violation for one item more than once ie: taillight, turn signal, brake light and required lighting all in one light being out and you have four violations plus a bunch of points. example
    10/10/2011 TX3BGE0AAC56 TX RJ7J58 TX Truck Tractor 19 3 57
    Violation: 393.11 No/defective lighting devices/reflective devices/projected (Non-OOS) 3
    Violation: 393.25(f) Stop lamp violations (OOS) 8 =6 (viol weight) + 2 (OOS)
    Violation: 393.55(c)(1) ABS - all tractors manufactured on or after 3/1/1997 air brake system (Non-OOS) 4
    Violation: 393.9 Inoperative required lamps (OOS) 4 =2 (viol weight) + 2 (OOS)
    serverity weight x3 = 57 points total one light 45 points yeah this system is great for those who want to rule us.
  3. shredfit1
    shredfit1 Road Train Member
    1,290
    583
    Nov 24, 2008
    MN
    Let's add warnings are considered as bad as citations.. and there isn't a distiction between them, if an inspection is done.
  4. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    In fact. Warnings are now worse than Citations where as you can not dispute them, or if you do, it goes to a Kangaroo court and never gets addressed!
    volvodriver01 and Roadmedic Thank this.
  5. TheRoadWarrior
    TheRoadWarrior rocking-n-rollin again
    1,058
    3,154
    Dec 6, 2011
    South West
    Ahhhhhhh welcome to the New World of Trucking... This is the prime reason im getting out after 40 yrs... to much goverment regs with little thought for drivers... imagine if they had CSA for 4 wheelers wow would we be able to get thru traffic so much better...Never happen...lol
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I did the input thing when all of this was open for public comments, but overall, I am not really all that concerned. If it all drives me out of business, so be it. By the time they weed me out, most of the carriers and drivers will have already been gone. Before it gets to that, there will be changes.
  7. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
    CSA is just a tool that is being misused, instead of tossing it out it would probably make more sense to learn how to use it correctly.
  8. revelation1911
    923
    308
    Dec 25, 2011
    Moody Alabama
    The problem there is the people who designed are the ones misusing it.
    Like the inmates running the assylum.
    I watcehd some of the listening session on video and they had to rig that too. I don't think there could be drivers that are that "slow"?
    Meltom Thanks this.
  9. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    Except in your example you fail to mention the 30 point cap on any inspection.
    All the due process is crap because all a bad SMS can legally accomplish is getting an audit.Yes other can compare you to your competition. If the system was half as flawed as the tin foil crowd would have you believe everyone would have these violations thereby negating bad scores within your peer group. The simple fact is poor inspection results will make one stand out.
  10. revelation1911
    923
    308
    Dec 25, 2011
    Moody Alabama
    You are wrong on the point thing. http://ai.fmcsa.dot.gov/SMS/Data/BASICs.aspx?enc=GmdPQKvdI/7sfUQKbt4hs8l2KuqZIyMhWNt/xyxSorc
    The mc # 675001 two inspections one 57 points andother 48 points.
    Wrong on other cuonts too. System is very flawed and there is no due process and all results from my personal experience are tainted. And you are wrong about the only thing you get is a audit you could go out of bussiness possibly. I have had several brokers check my score before loading me.
    so take the two big facts improperly inspections= flawed data and then throw in missing loads due to this. The system is a piece of sheit and needs scrapping.
    Roadmedic Thanks this.
  11. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    First, let me say I am not a proponent of the CSA program, and frankly I don't have anything to do with it. My job is to do vehicle inspections. Somebody down the line after me takes my inspections and assigns point values to violations, crunches numbers, assigns carrier ratings, etc. CSA did not change anything about the way I do inspections.
    I do understand, however, the sentiment of many on this forum about the impact of CSA on drivers and carriers. I hear you, but since I have nothing to do with CSA I do not know the answers.
    I do have some questions for you Rev, maybe you can help me.
    If you Data-Q challenge a violation on one of my inspections I will review my inspection and verify the information. I am not perfect, not by a longshot, and I make mistakes. If I entered a violation on an inspection in error, I will gladly remove it. Only "valid" violations will remain on an inspection report. Is that not addressing the validity of information?
    What do "due process" and "guilt" have to do with a vehicle inspection report? The vehicle is examined and required equipment either functions or it does not. A required lamp either works, or it does not. A brake is either within adjustment tolerance, or it is not. Defects are noted on the report.
    If you are issued a citation for something, then we are talking about things like "due process" and "guilt" or innocence.
    What reasoning is there to be cited for a turn signal that does not work? It either works, or it does not. I am simply reporting whether or not the required signal lamp was operative at the time of inspection. No intent is implied. No acts of God to be considered. It is called an "Inspection Report", says so right at the top. I am simply reporting, not assigning blame or intent.
    I don't know about anywhere else, but if I falsify inspections, or violations on inspections, I will be out of a job PDQ.
    I make this deal with you Rev. Any violation I put on an inspection report on your vehicle will be one I can show you and have you agree with me on whether it functions properly or not. We can stand at the back of the trailer and both of us look at the turn signal to see if it works or not. You can measure the pushrod with your ruler, check tire pressure with your tire gauge, look at a wheel and count the missing lugs together, etc. In short, I promise not to be a "marauder"!:biggrin_255:
    corneileous Thanks this.
