Cummings ISX 2005 constant high idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Leon Nicholes Jr, Sep 26, 2018.
  1. Leon Nicholes Jr
    Leon Nicholes Jr Bobtail Member
    What would cause it to run at high idle all the time?
  3. dmkberger
    dmkberger Bobtail Member
    7
    Sep 26, 2018
    Leon, my guess would be a vacuum leak somewhere in the intake. I've been out of the field for a while but this is my best guess. Hope that helps.
  4. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
    What is high idle? How fast?
    Vacuum leak is more of a gas thing. 2005 isx idle speed will be controlled by the ecm.
    Goodysnap and spsauerland Thank this.
  5. dmkberger
    7
    Sep 26, 2018
    Yeah, I thought of that later and just didn't come back to fix the post. Thanks for the refresher...
    pushbroom Thanks this.
  6. Heavyd
    Heavyd Road Train Member
    7,805
    6,255
    Feb 4, 2009
    Check for a stone or mud or something jammed under the throttle pedal.
    AModelCat Thanks this.
  7. shoe128
    shoe128 Bobtail Member
    47
    12
    Jun 30, 2018
    Depends on what you call high if it's
    7-800 it's sounds like it's Ina Regen mode my isx15 .2016 does it allows
  8. tallmon
    tallmon Medium Load Member
    657
    320
    Oct 22, 2014
    Did you ever figure out the problem? I have a 2007 idling at about 750.
  9. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Turn cruise off and push acceleration or resume to change idle speed. If turned on in programming allows you to change idle from 600 to 900 rpm.
    tallmon Thanks this.
  10. Bobby/Ronda
    Bobby/Ronda Bobtail Member
    My 2011 isx Cummins is idling high
    No road power pulling load
    Any help for this
    I already changed the tps foot pedal assembly
