Cummings isx fault codes
Discussion in 'Kenworth Forum' started by JRBES, Jun 5, 2016.
  1. JRBES
    JRBES Bobtail Member
    17
    4
    Jun 22, 2015
    Post up your cummings fault codes and engine serial I'll provide the rest.
    For example fault code 1620, 2973, 3582, 3232, 0195, 0197 etc....
    1620 got this one 5 times different trucks. Def light low fluid blinking. Def pump yes turned on. However it failed to prime. Replaced Def pump.
    3582 this code requires a update to your ecm and you will need to replace intake noxx sensor 1. If you get the code again you will need to replace scr.
    3232 intake noxx sensor 1 abnormal rate replaced noxx sensor fixed.
    0195 0197 coolant level sensor shorted to high source etc... had these on 2 different tractors. 6 broken wires on drivers side both kenworths.
    2973 you will get this code along with the intake manifold pressure/temp sensor. You clean or replace intake temp sensor and it will come back. If you don't see the 2973 code replace turbo speed sensor.
    I got alot of cummings isx codes but to get you engine specific codes will need a serial number to help. I don't promise to help you fix but you will get the info you shall need!! Cummings only!!!
    bigmotor1212 Thanks this.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,500
    9,782
    Mar 30, 2014
    I never had a fault code with my Cummings ISX, only when I drove a Cummins did I get any. Does that mean a Cummings is better than a Cummins?
  4. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    I hope not I have a cummins also
    Bean Jr. Thanks this.
  5. JRBES
    17
    4
    Jun 22, 2015
    Yoo comedians got quick serve let me know when ya need me is free!!!
    bowhunter67 and Bean Jr. Thank this.
  6. scorpsrus
    scorpsrus Bobtail Member
    Green lake Wi
    I haveva 2005 T 2000 with the isx Cummins and the Eatonfuller autoshift...I have been dealing with shifting issues for a week....eaton fuller tells me it a ecm issue..but Im not getting any fault codes from ecm or transmission.
    It will go into.gear fine. But will not shift up when in D .it usually shifts when O put in manual mode and I push the button....but only run up to 1475 rpms and no speedo.no cruz no jake.
  7. JRBES
    17
    4
    Jun 22, 2015
    Did you check your battery connections? Ensure you have no corrosion inside the wires. Even if you don't see corrosion sometimes you can't see it. These autos must have good electrical voltage at all times.
    Do you know what exact transmission you have?
    Have you had the truck scanned with service ranger? That's Eatons, program to read the ecm. You may not have active codes they may be inactive.
  8. Ljexile
    Ljexile Bobtail Member
  9. Ljexile
    I fault code 3582 active code 3569 inactive what can you tell me about this engine # 79532724
