Cummins 290, oil in coolant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Sep 30, 2021.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,353
    1,707
    Dec 4, 2019
    Getting oil in my coolant. Stuck to bottom of radiator cap and coming from overflow tube. Oil cooler was replaced about 5 years ago and 10,000 miles ago. Could it be the compressor or oil cooler? What’s more likely and how to determine?
  3. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Remove both the Oil Filter & the Oil Pan.
    Pressurise the Cooling system.
    If Coolant drips out the Filter Head it's the Oil Cooler.
    if Coolant drips from the Oil pan area you need to Dig Deeper. Much deeper.. (Most likely electrolysis or a Liner O ring)
    Dino soar, BoxCarKidd and Bean Jr. Thank this.
  4. mile marker 27
    1,353
    1,707
    Dec 4, 2019
    After running the truck hard, It sat for a day and without starting it, I changed the oil and oil filter. Absolutely no sign of water in the oil, at bottom of pan or filter.
  5. Inderjit
    Inderjit Heavy Load Member
    745
    725
    Sep 17, 2017
    Is there coolant in the oil? Pull a valve cover and see if there is sludge
    building up in the top end. It usually shows up on the bottom of the valve covers.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    The oil cooler is about the cheapest place to start if Inderjit's test is non conclusive. How old is the compressor?
    Big Road Skateboard Thanks this.
  7. Big Road Skateboard
    6,727
    37,862
    May 2, 2021
    If you have oil in the coolant, you've got an oil cooler issue.
    Change the oil cooler. You're gonna have to flush 5 or 6 times to get the oil out. Don't worry when you noticeca bit more show up in the coolant, it's hard to get all the oil out.
    BoxCarKidd Thanks this.
  8. mile marker 27
    1,353
    1,707
    Dec 4, 2019
    I do nearly all my own wrenching so, how hard is to oil cooler to remove and what do I need to know about doing this job?
  9. Big Road Skateboard
    6,727
    37,862
    May 2, 2021
    No special knowledge needed. Pretty easy job, just need lots of Cacade for flushing
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    I thought that once. Two weeks later it was worse. Engine had a cracked liner.
    You wanna fight? I do not just sharing.
    Big Road Skateboard and haycarter Thank this.
  11. Big Road Skateboard
    6,727
    37,862
    May 2, 2021
    And no oil coolant in the oil? Did a mechanic tell you this was the cause of a failure, or did you find it yourself?
    The reason I ask, and I'm not trying to be condescending. On older engines, there is absolutely no where besides the oil cooler, where pressurized coolant and oil are together. There is no pressurized oil around an injector cup or liner. I'm not saying it didn't happen, but I've seen hundreds of cracked liners. There's almost no way for splashed oil to penetrate a crack in a liner, or to get past a bad liner o ring.. If the crack is above the piston, you'll get pressure in the cooling system, and likely some coolant out the exhaust, and below you'll get water in the pan.
    Any other failure, say in an air compressor, could also put compression in the cooling system or coolant into the oil, but not oil into the coolant.
