Cummins 370e+
Discussion in 'Trucks [ Eighteen Wheelers ]' started by See Are125, May 30, 2013.
  1. See Are125
    See Are125 Light Load Member
    78
    40
    May 23, 2013
    What can this engine be turned up to? I know it's 370hp, but how far can you go? 410, 425? Can't find much on the 370e+ but have found some info on the M11 in general, and it appears there are 2 M11 configurations. M11 and M11 Celect Plus. I'm guessing this is the Celect Plus? Looking for something 400hp+, but this one is in my budget. Just curious how much I can turn it up. Still want reliability though. Thanks for the help. Oh, and it's in a 1997 T800 if that helps. Thanks again!
  3. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Get a N14. The one I have in a 99 volvo has the 370/460 hp program. It can be turned up with just a electronic tune. To see what your engine can be turned to per the original specks, take the engine serial number to a Cummins dealer and have them look it up for you. You can call the regional Cummins distributor and have them look it up. These old trucks are cheap, so get on with a reliable motor. The one I got is just $6000. Good luck with finding a truck.
  4. Haulindave
    Haulindave Bobtail Member
    14
    Mar 8, 2013
    Don't know much , but I have M 11 370hp and it had the emc flashed I think and had a 400plus Hp in it when I got it . Had Freightliner reflash or reprogramed the emc because it started missingup and put it back to 370hp . EMC works ok now but sure do miss the extra HP .
  5. little cat 500
    2,048
    1,093
    Jan 17, 2010
    Abbottstown PA
    if you go with a different cpl # you can get more out of it we have a N14 that was a 370 i think it was a cpl 2591 took it to greencastle now its little over 500 on the ground per there dino
  6. cetanediesel
    470
    186
    Mar 26, 2013
    Albany, NY
    LMAO, thanks. That would make it stand on end.
    I dont think I need 500 for 33K lbs.
    Would be a rocket for sure.
  7. little cat 500
    2,048
    1,093
    Jan 17, 2010
    Abbottstown PA
  8. See Are125
    78
    40
    May 23, 2013
    So the M11 Celect Plus can be turned up electronically and the M11 has to be turned up with hard parts? Anyone know the year they started the Celect Plus? I'm looking at a 96 and a 97 model. The guy with the 96 doesn't know if it's a Celect Plus or not. The 97 just said it was a 370e+ which from what I can tell is a Celect Plus. As much as I would like to have an N14 or ISX I can't find one in a single axle truck, and the tandem trucks I have found are already near my budget and removing an axle or shortening the frame would put me over my budget. I still have a trailer to buy as well.
  9. Haulindave
    14
    Mar 8, 2013
    Mine is a 96 FLD 112 celect plus 370hp , just program the ECM .
  10. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    41
    Sep 2, 2009
    I have a 96 m11 celect 350hp i have heard of guys with marine m11 applicataions going up to 500hp but i wouldnt push the little small block more than 400hp, i like my 350hp m11, for what i do it does a great job and compared to other engines it cheap to work on and i get around 7mpg
  11. See Are125
    78
    40
    May 23, 2013
    Thanks for the info. Looking to get somewhere around 425hp out of it.
