Cummins 444 ???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bent Wrench, Oct 10, 2011.
  1. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Throttle is very sensitive / touchy. Very hard to match rpm on downshifts as very light throttle causes RPM to flair excessively.
    Very light throttle in low gears and the motor surges or lunges.
    Has stuck more than once at 2000 rpm without any apparent external linkage issues. Blipping the throttle did not bring it down. Letting out the clutch in gear (rolling still of course) brought it back down.
    I'm thinking this is a just governor adjustment?
    Is the oil pressure adjustable? 10-15 at hot idle. Jakes quit working at 25psi - 1500 rpm.
    Could the low oil pressure also cause the governor problems?
    Just coming up on 400,000 miles so it's barely broken in!
  3. ironeagle2006
    ironeagle2006 Road Train Member
    Cummions 444 a fine Motor 10-15 PSI at hot idle is about Normal with worn Bearings might want to roll a set into her. Jake issue and the hang up have a clue what is going on man I love the fact I drove one of these things that was a BEAST. Check in the Injection pump for a weak Governor Hold down Spring if that is bad replace it and also replace the Governor Button with a 6 button. Trust me you will love the Performance gain in the HILLs. What is happening is this your Engine is refusing to go back to Idle also replace the Oil Pump while your replacing the Bearings 444's where notoriuos for weak Cranks unless you had plenty of Oil Volume not Pressure. If you plan on keeping this an using her as a daily worker find an old BC 1 series and get the Water inlets off that motor then Put a High Flow Coolant System on the 444. Put an Air to Air instead of a Water Cooled Intercooler on it. Will lower your Exhaust temp about 100 Degrees and gain you about 50 HP without requiring BIG Bucks. Drove a 444 with over 800 To the Ground.
    See mine Snapped a 720HP chassis Dyno like a twig I still had 50 Lbs of Rail Pressure and was still building to the top end of the Powerband when the Dyno let go. Computer said over 850 EST based on setup and seeing how that old girl hammered UP Snowshoe in PA and the Steel Haulers were Pulling over. I knew I had something Big there.
  4. Bent Wrench
    588
    205
    Aug 11, 2009
    Cornholio, OR
    How much boost should this motor make?
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Check the return fuel line to see if it is plugged, sounds like the rail pressure is not coming back down quick enough.
  6. Dexterr
    Dexterr Medium Load Member
    384
    327
    Jul 25, 2011
    Lafourche parish
    Never seen a 444 but heard about them
  7. Old Tom
    Old Tom Light Load Member
    165
    123
    Sep 22, 2010
    SW Ontario
    Drove a Freightliner Special Edition with a 444 18OD and 3:55's for a month or so in the early 90's. Took it up to 105mph and it still had pedal left. I talked with a couple of engineers when they were building the (then) Freightliner plant in St Thomas, ON. They had built this truck in BC and had an interest on how it was running, so I asked them 'just how fast will this thing run?' - answer = 127mph.
  8. kmax05
    kmax05 Bobtail Member
    20
    Nov 22, 2010
    North east
    Sounds like air in your fuel system. leaky throttle shaft.
  9. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Check that the throttle lever is tight where it mounts onto the pump shaft. The shaft is splined & the lever is held by a 1/4 bolt. The bolt can loosen & the lever moves on the shaft. Also the lever is hinged to allow it to break over when the throttle shaft hits its stop. The lever has its own spring to hold it straight. The spring can break & allow the lever to flop around & can cause the problems you have.
