Cummins Big Cam
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ManilaButton901, Feb 17, 2022.
  1. ManilaButton901
    ManilaButton901 Bobtail Member
    11
    May 17, 2018
    Hello all,
    I am going to look at a truck this weekend, the owner said it was a ‘79 359, but the title says it’s an ‘80, and the owner says it has a Big Cam in it. I don’t know anything about Cummins engines, especially older Cummins engines. The owner hasn’t done much work to the truck since he bought it. He said he found it in a field about 10 or so years ago and had it towed out of there and got it running and hadn’t done much with it since.
    My questions are how do I find out exactly what engine is in this truck? How can I look at it and tell what it is? The owner said the engine data plate is missing, but he had a new one made by Cummins, but has misplaced it before installing it. Is there a database that I can look up the engine serial number? I don’t have the engine serial number yet. I do not know the CPL to this engine. How can I tell with a glance if it has the low flow or the high flow cooling system?
    Any help would be appreciated. Also, if there’s anything I should check on this engine before I buy it or if you need more info, please let me know.
    Thanks for all of the help!
    Wannabe tech Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    79/80 that should be a BC1. I think the cooling system change was on the BC3 engines.
    Rideandrepair and ManilaButton901 Thank this.
  4. SmallPackage
    5,778
    18,555
    Dec 20, 2019
    Marion Texas
    Early engines had id number stamped on block on a machined pad on left (intake side) front below the front head behind air compressor. Later blocks had it on the rear block machined pad below the rear head.
    Should have BiG CAM cast in block on same side below the large cam followers. ( some early big cams did not have big cam cast in them. But by ‘79 they would have if it is original.
    That number will tell you what it was originally assembled as. But being 40 plus years old it could have been overhauled to be anything in its lifetime.
  5. SmallPackage
    5,778
    18,555
    Dec 20, 2019
    Marion Texas
    That engine will have the high flow cooling and should also be higher oil pressure. Unless oil pump was changed to later low pressure during an overhaul. Low flow cooling did not come around till ‘84
  6. ManilaButton901
    11
    May 17, 2018
    Thanks for all of the responses! I’ll check it out on Saturday and see what I can find.
  7. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    Iam not a Cummins guy so Iam not gonna be of any help there .. but just a few things to think about since I fool around with 359s if that truck has been sitting and not had much done .. your gonna be a busy guy getting it road worthy and it's not gonna be cheap
    I''am not even gonna talk you in or out of buying and I am not gonna begin to tell you want it costs just in parts
    There's 2 members here that have done it and made Ytube videos you should watch them to know what your up against.. @ Easy Rider & @TwinStickPeterbilt
    Maybe @wore out will speak up
    But he like myself is a Cat guy but he knows 359s very too
    Good luck on your endeavor
  8. ManilaButton901
    11
    May 17, 2018
    Here’s what I just received from the seller.
  9. wore out
    wore out Numbered Classic
    17,324
    215,142
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I am not a fan of Cummins but the 393 and 676 CPL are my favorite. I have no idea what your hopes or intentions are for the truck.....let me just say it’s a long hard expensive and very heartbreaking ride to bring one back from the edge of the grave. Getting it road worthy is kinda the easy part but it’s not easy. Once you get that much money in it it sucks to not make it nice.....there is the heart break and hard work. So many look nice at a glance but if you start digging then you see the the smoke and mirrors. Like @Catmando said I won’t try to persuade you but this is one time you may be better off leavin that thing where she is and wondering what mighta been
    LameMule, tnt440, D.Tibbitt and 5 others Thank this.
  10. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    O yea that plate looks good but finding out it belongs on the motor that's in the truck now will take some digging into the numbers on the block that's in it now?
  11. ManilaButton901
    11
    May 17, 2018
    I’m going to look at the truck tomorrow and I’ll check to see if the engine serial number matches what’s on the block. Is there anything else I can do?
    baha Thanks this.
