Cummins CNG/LNG to diesel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gthompson97, Sep 26, 2023.
  1. gthompson97
    gthompson97 Bobtail Member
    Did some searching but couldn’t find quite what I was looking for.
    Has anyone successfully swapped from a NG/LP fueled truck to a diesel engine? We farm and do 99% of our shop work ourselves, motor repair/swaps, tranny swaps etc, so that part doesn’t scare me, but short of the long block/accessories, engine harness, fuel/tank, what else is different? Coolers? Is the base wiring the same in the cab? We run all ISMs so I would be mostly looking at swapping from an ISL or ISX12 G to an ISM.
    Some of these 10ish year old alternative fuel trucks can be bought very reasonable with <500k on them. I’m always looking for a challenge (recently put a pre-egr motor into a 2007+ truck) but I don’t want to get into it so far that dash harnesses, computers, and the entire truck needs to be rebuilt.
    Edit to add: Would most likely be on a Pete 384 or a 579.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,028
    5,412
    Mar 18, 2021
    St Malo mb
    Maybe use search feature and look for old threads on gliders . There used to be some companies making harnesses for swaps before the gliders got shutdown on new trucks.. a buddy has a cascadia that used to be cng other than having a preset high idle switch I believe everything works . He bought it converted
