cummins code 431
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckmechanic, Mar 15, 2012.
  1. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Here it goes guys I've been troubleshooting a code 431 on a cummins idle validation switch here's what I've done I've replaced potentiometer and harness one new and one good used setup I've swapped ecm with a know good one I've pulled the oem harness and inspected and replaced all the wires from ecm to gannon plug on the firewall problem still persisted intermittent check engine lite and idle only tap the throttle and it goes away then comes back when you gently push the throttle so I ended up finding the wires in the cab and bypassing them still did the same so I put in a another new potentiometer calibrated it and now its all good so here's the question one been working on this project off and on for a few weeks when I get a chance I think there's a short in cab harness do you think it could have shorted out the other potentiometers or am I crazy this is one of those projects that maked you bang your head on the wall so what so you guys think any experiences you've had with some electrical gremlins will help thanks guys
  3. rediron6
    rediron6 Light Load Member
    50
    Aug 10, 2011
    albany, ny
  4. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
  5. rediron6
    50
    Aug 10, 2011
    albany, ny
    checked cummins and it sounds like you have a calibration issue. the pedal needs to be calibrated.
  6. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Already did multiple times with diffrent harness and potentiometer same problem opens oem harness replaced all wires same thing bypass wires under dash same code with same potentiometers put a new one recalibrate and now its all good so I'm thinking I have. A short in the dash harness and its damaging the potentiometers I tried 2 new ones and 2 used ones that were good any thoughts all I know is it seems fixed so I'm sending it back to work
  7. Heavyd
    Heavyd Road Train Member
    7,755
    6,190
    Feb 4, 2009
    Cummins and Cat pedal sensors are different electronically, but visually identical and will bolt and plug in. If you are swapping sensors around the problem doesn't go away, make sure you have correct part number.
    truckmechanic Thanks this.
