Cummins EGR using coolant?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CUMMINS downunder, Feb 24, 2010.
  1. CUMMINS downunder
    CUMMINS downunder Bobtail Member
    7
    Sep 22, 2009
    New Zealand
    got a k108 Kenworth running hot and putting 10L coolant a day in. only done 140000km. these new to nz and is 1st one we havn greif with. any ideas?
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    EGR coolers can go bad, it is a common problem, and push the coolant out the exhaust, staining you pipes, sometimes called wet stacking. If not under warranty can be an expensive repair, have heard of a few guys working for cheap companies that have been told to just keep adding antifreeze!
  4. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Yepper.... EGR coolers do blow a leak once in a while. Not a cheap repair.
  5. isxcummins
    isxcummins Bobtail Member
    8
    19
    Feb 27, 2010
    mn
    I have seen a few EGR cooler failures on the new ISX at the shop im at. Try to get it serviced asap, espically if not under warranty. If left to long it can lock up your EGR valve, gunk up your vgt and even cause DPF problems. All engine brands seem to be having problems with EGR coolers since the new emmission standards of 2007+.
