Cummins engine burning 1-1.5 gallons of Engine oil a week with excess blow
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Jan 1, 2021.
  1. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    1. Blowby is a sign of worn or broken piston rings. Accompanied by high oil consumption.
    Blowby contaminates the oil to the point of low to no pressure. Changing oil and filter will bring it back up for a short time when it gets bad again.
    I was losing 3 gallons a day on a cat motor with 200k miles. Cat had a modification for that problem. Oil consumption was reduced but then the pressure problem came up. Oil change every 2 weeks.
    The story i got from the mechanics was cat using undersized pistons. When winter came and the truck could be parked. It got torn down. All 6 pistons had broken top rings. The second rings were fine.
    That motor got new pistons and cylinders and whatever else. At 250k miles.
    Gurjap and bzinger Thank this.
  3. MACK E-6
    49,652
    234,051
    He’s talking about oil burn, not oil LEAK. ;) :biggrin_25523:
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I'd keep running it for the time being. Probably will keep running for a while like that
    Gurjap and joey8686 Thank this.
  5. 201
    201 Road Train Member
    12,621
    25,906
    Apr 16, 2014
    high plains colorado
    I know, Detroits were 2-3 gallons, but I drove MANY Cummins powered trucks, and a gallon a day was considered normal. Even the Mack I drove used a gallon a day, it was no big deal, fact is, it got to the point, while fueling, we just add a gallon. Came out of a big tank, probably cost $1 a gallon. Much cheaper than a rebuild,,,
    MACK E-6 Thanks this.
  6. bad-luck
    bad-luck Road Train Member
    3,359
    6,212
    Nov 16, 2013
    Baltimore, Maryland
    Time for a rebuild. The engine had a good run, at 1.3 million. It is only going to get worse, and you run the risk of spinning a bearing with the oil pressure getting low if you continue to run it. If you spin a bearing, your block will get destroyed
    Gurjap, bzinger and joey8686 Thank this.
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    OP
    Have you considered using any oil additives like Lucas...
  8. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Yes, the emissions system is intact and on the terms of replacement it has had, turbo, actuator and bottom end. I will look into rawze thank you
