cummins engine
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by dreammaker, Mar 7, 2012.
  1. dreammaker
    dreammaker Bobtail Member
    13
    Oct 13, 2010
    knoxville ,tn
    Can anyone tell me about a vgt valve on a isx motor were it is exactly and can you tell your self if ones gone bad? My truck is running sometimes like it has a bad indejestion jerking real hard and loses power:biggrin_25523:
  3. Kujo
    Kujo Medium Load Member
    442
    168
    Feb 6, 2012
    in the middle
    Edit for accuracy. If the controller is bad most shops aren't going to check. Don't know why but most will just change the turbo and call it good. Problem is if its in the sensors or pcm then it won't fix the problem. If your shop doesn't know then hopefully they'll send you to a dealer or factory shop if so insist they check it all and not just change the turbo.
  4. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Mine's in the shop for the EGR fouling up the VGT....
    All too common for Cummins EPA engines....:biggrin_25510:
  5. Kujo
    442
    168
    Feb 6, 2012
    in the middle
    83k miles on mine have had the turbo go out and the egr cooler in the same week. A month later the fan clutch went out. All that was in the first 40k nothing wrong since.
