cummins fault code 2372
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allbusiness, Apr 20, 2015.
  1. allbusiness
    allbusiness Bobtail Member
    18
    4
    Feb 16, 2013
    St.Catharines, On Canada
    I'm hoping that someone out there can help with my problem. I have an '06 pete 379 with an isx 475, it intermitant problem where it throws a 2372 code and derates engine power. It may last an hour or so, and when I shut the engine off and re fire, the check engine light goes off and all is fine. I have taken it in to Peterbilt and had the code read on monday the 13th and the 2372 code came up restricted fuel filter, so i had them change both filters and it was fine until friday when it started acting up and throwing the code again. So today which is monday i went back to peterbilt to have the code read and it was the same one. Has anybody encountered this same problem and what was the outcome?
    Thanks for reading and I hope to hear from someone before Peterbilt sucks all of my money from my pockets..:biggrin_25516:
  3. Heavyd
    Heavyd Road Train Member
    7,763
    6,201
    Feb 4, 2009
    The engine is detecting low fuel pressure. Fuel pressure testing needs to be done. If changing the filter temporarily fixes this, I would say your fuel is contaminated. Other than that it could be bad or sticking fuel shut off solenoid, or restricted fuel intake, or even a bad pressure sensor.
    bubbanbrenda and allbusiness Thank this.
  4. allbusiness
    18
    4
    Feb 16, 2013
    Thanks Heavyd, I am going to try all of your ideas. Hopefully it's just some bad fuel, but i'll change the pressure sensor and then have a look at the fuel shut off solenoid. Thanks for taking the time.
    Heavyd Thanks this.
