Cummins ISC Throttle behaves like an on/off switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mach, Dec 14, 2025.
  1. Mach
    Mach Light Load Member
    185
    140
    Nov 19, 2017
    Knoxville Tennessee
    2009 Kenworth T370
    Paccar px8 / Cummins ISC with weight reduction kit
    1.1 million miles / 29919 engine hours (rebuilt in 2021 at 780k miles)
    Been dealing with this issue for a while. Talked to both Kenworth and Cummins and no one seems to have any idea what's up
    Throttle pedal acts as an on off switch when trying to accelerat slowly or for slow driving. When stopped, the pedal has a small dead zone at the top where it does nothing, but after that, if you try to accelerate and hold the engine rpm at something like 800 or 1000 rpm, it will take off untill about 1500 rpm. I can hold any speed lower than that unless the engine is stone cold and fluids are thick. I can hold about 1200 then but nothing less. While driving with a load on the truck but at slow speed, it will accelerate and almost hold at around 1300 rpm, but then the turbo usually kicks in building boost and thus accelerating the truck more, all while barely touching the throttle.
    I can set the idle with cruise controll at what ever speed I want with no issues. And driveing with cruise control, the truck doesn't seem to lurch forward after coasting and coming back into power. It can do that slowly. If I coast down a hill and try to gradually come back into power, there will be a sharp hit in the drivelive as if you stabbed the throttle hard. And yes drive line u joints and carrier bearings are tight. The acceleration is just so violent you hear and feel it everywhere.
    So as you can tell if I'm trying to just slowly drive through a parking lot or stop and go traffic, the truck will just put h forward and accelerate. I usual just have to put it in the tallest gear possible and coast with the clutch out. This is wrecking havoc on my drive line with the shock when it accelerates
    The pedal is a floor hinge accelerator with a 5 wire Throttle Position Sensor. I've replaced this thing several times and that does not help. There's supposedly a calibration process where if the key is on, you press the pedal down slowly and then release slowly 3 times in 30 seconds or something like that but that does not fix the problem. Looking at insite, there's no way to calibrate the throttle there either
    Anyone have any ideas? Truck is old and has a lot of miles so it could be anything. But I'll take any advice as this is insanely annoying.
    Thanks!
  3. Mach
    185
    140
    Nov 19, 2017
    Knoxville Tennessee
    Dang no one has any ideas? Lol seems to be the running theme no matter where I go. Ah well. One of these days I'll figure it out
  4. wore out
    wore out Numbered Classic
    16,781
    205,441
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would look in the harness itself, specifically close to the pedal. I’ve never worked on a T3 but that’s where i usually find the issue. Sometimes it’s insulation rubbed through and grounding. Other times it’s broken or corroded inside the insulation where the only way to find it is load testing the circuit
    Hammer166 and Diesel Dave Thank this.
  5. Mach
    185
    140
    Nov 19, 2017
    Knoxville Tennessee
    Pedal is harness is exactly the same as the floor hinged versions in the older t800s and what not according the KW if that means anything. I have looked at the harness there and it seems to be in great shape all the way till it disappears behind the foot wall going behind the dash. That part I can't inspect in any way. Does anyone have possibly voltage numbers? If there's any form of resistance, I can check that with a multimeter but I would need to know what's the nominal range for those
  6. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    If you have Insite, monitor the throttle pedal percentage and slowly press the pedal down and watch for smooth increase in percentage. That year should also show idle on or off from the idle validation switch. Also check for any codes. If you have wiring problems or pedal problem you will spot that easy with Insite.
  7. Mach
    185
    140
    Nov 19, 2017
    Knoxville Tennessee
    I did actually just get insite so I'll have to do that. I'm assuming a sign of wiring issue will be a voltage spikes or dips when slowly pressing or depressing the throttle?
  8. Heavyd
    7,812
    6,265
    Feb 4, 2009
    You can watch the percentage, or signal voltage to help with that. The ECM acts like it's own volt meter.
