Cummins ism 410 3.42gears pulling flatbed
Discussion in 'Flatbed Trucking Forum' started by ATZ, Dec 15, 2012.
  1. ATZ
    ATZ Bobtail Member
    Hey guys I am looking at a 2003 International 9200i with a cummins ism and 3.42 gears 10spOD. Is this to small to handle loaded flatbeds? How about MPG? I will be driving mostly flatland but there may be a few hills along the way. MPG and reliability are much more important to me then high speed. The truck is $18000 and has 580000 miles. I will put about 2000 miles per week on it. Thanx for any advice
  3. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    a lot of drivers put a lot of miles on old 220 cummins, and did ok with that.
  4. TripleSix
    129,325
    Measure twice. Cut once.
    I guess the main selling point on this truck is the price. Flatbed loads can be quite heavy (steel, lumber, pipe, roofing shingles,...etc). Other loads can catch alot of wind (containers). Plus, there are the Appalachian Mountains running through the easter freight lane (eastern Ohio, Pa, Wv, Va, NY, TN, NC, North Georgia and North Alabama). For a city truck/ 3 state regional, I guess it would be fine, but for a road truck, no. 410 HP is low. Lower than the average fleet truck on the road that was spec'd by the big fleet beancounters.
    I always reccommend to my guys looking at trucks to go with minimum 475 HP for best performance on a road truck. The gear is fine and the tranny will work...I just think the HP is too low. YES, you can make it work, but buying something to make it work is not a good idea for an O/O. Lots of drivers will go out, and buy the typical doorslammer spec'd fleet truck, turn her wide open, 430 HP/10speed/3:42s, put beacons lights on, and try to rub elbows with me. On the other end of the load, I wind up spending $500 less in fuel on 1 load.
    You can buy a stronger truck for the same amount of money. Fleet trucks are extremely cheap.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ISM is a good engine but the most expencive injectors, more expensive then M11 and N14.
    But fuel milage is better the ISX
  6. rank
    rank Road Train Member
    9,918
    113,501
    Feb 11, 2010
    Thats a similar setup to what I drive. Mine is a 1998 t8 with a a 370/400 M11, 13od,22.5, 4.33. 6 to 7 mpg at 60 mpg up and down I81 in NY and PA. I wouldn't want less gear.
  7. Calspring
    Calspring Light Load Member
    290
    144
    Jun 22, 2012
    Canada
    I have no experience with the engine myself but it should work, you will just be slower from a stop and won't be able to hold speed as well as others going up hills. My dads first truck was a 237 mack and he would joke that you could take a nap going up hills. Its a pissing contest now with engines for some people. Does everyone need 500+ horsepower. No, but they want to beat everyone to the top of the hill.
  8. TripleSix
    129,325
    With 4:33 gears, you can change the rotation of earth. You could just about pull twice the weight that OP would be able to.
  9. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    I personally think 500hp n-14 Cummins is not enough to containers. Get a good 60 load and a good grade you'll find yourself doing about 35 coming over the top of that hill.
  10. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    I would rec. going with bigger engine. The most HP you will get out of that engine is 425 if I am not mistaken. I would find an ISX set at 475 or higher or a C15 set at 475HP.
    KH
  11. spacetrucker88
    spacetrucker88 Heavy Load Member
    18 grand try it you can make that back in 6 weeks,
