Cummins isx 15 coolant loss no external leak
Discussion in 'Volvo Forum' started by RoadRanger^^, Jul 12, 2025.
  1. RoadRanger^^
    RoadRanger^^ Medium Load Member
    309
    115
    Apr 17, 2018
    Columbus, OH
    I start loosing coolant on my truck after replacing the radiator. No leak but i keep loosing coolant.
    Oil is clean, crankase breather is clean, transmission cooler is by passed, egr is deleted, no white smoke out of the exhaust. Where is this coolant going ? How much air can be trapped in the system if possible ? Truck is running fine no overheating
  3. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    Update: it was the air pockets in the cooling system, i didn’t do the right procedure to get rid of the air after refilling the system, i will run it and will update soon once again to confirm it was the air and not some other issue
    dosgatos, D.Tibbitt and QUALITYTRUCK Thank this.
  4. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    Well…
    It went from max to min again. I decided to do a combustion leak test with that blue fluid from amazon, unfortunately my engine failed, color changes from blue to green meaning that is comb gases in the coolant and leading to head gasket or cylinder head issues. What are you guys thinking ? Once again, it does not puke coolant thru the reservour, no smoking no coolant in oil. Could be something else like air compressor ? I have replaced only the head on the air compressor not long ago i think i bought it on amazon, could have failed that one ?
    D.Tibbitt Thanks this.
  5. D.Tibbitt
    152,250
    Do u have little blake flakes in the coolant? I had a 386 blow the head gasket and it failed the block test like yours and had little blake flakes . But i had a ton of excess pressure in the system it was puking coolant everywhere... I guess the cheapest place to start is pull the back clamp on egr cooler and see if its just the cooler leaking.. if not that then test compressor ... You could also pull your exhaust manifold off and see if exhaust ports are wet with coolant but obviously its a couple hours job to do that..
  6. Diesel Dave
    8,920
    26,613
    Jan 20, 2010
    Hesperia, Ca.
    My only .02 is I wouldn’t purchase any engine components from Amazon. I do Genuine.
    JB7 and RoadRanger^^ Thank this.
  7. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    I did not noticed any blake flakes to be honest but yeah this one is making normal pressure in the reservoir. I mentioned above, my dpf and egr is deleted, so my question is, is there still going coolant thru the egr cooler ? Exhaust manifold is good pin point to check but it will be more then couple hours especially if them bolts snap
  8. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    That is my fault, i should have bought the whole unit together even reman was better.
  9. QUALITYTRUCK
    1,813
    1,776
    Jun 14, 2009
    romulus,mi
    Cooler still has coolant passing through it, even though there is not any exhaust gas flowing through it any longer. Think of cooler the same way you think of a radiator, except that coolant will leak into exhaust flow instead of on ground like radiator.
    RoadRanger^^ Thanks this.
  10. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    Is there a way to check egr cooler for leaks or do i have to take it apart to find out ? Do you know if turbo and manifold needs to come off ?
    thank you
  11. RoadRanger^^
    309
    115
    Apr 17, 2018
    Columbus, OH
    If i remove this little flex pipe, will i be able to see if there is any leaks ? Also on the flex pipe from the exhaust i see some white and reddish mark.
