Cummins ISX 2011 Engine Fuel Filter (Suction Side) Differential Pressure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tallmon, Aug 14, 2015.
  1. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    Getting this weird code. Fuel pressure indicators all normal, fuel filter recently replaced.
    Engine Fault Code (||16|0)
    Fault Description: Engine Fuel Filter (Suction Side) Differential Pressure (see also SPN 1382) Cab Controller - Primary Voltage Above Normal, Or Shorted To High Source
    Cummins ISX 2011 on a Kenworth T700
    thanks
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Curious about this too. I get the same fault on my isx 11 prostar. About once a day It pops up.
  4. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    This code is set when the ECM detects the fuel pressure is actually dropping at higher engine rpms. Basically low fuel pressure. Could be primary or secondary fuel filter, suction restriction, sticking fuel shutoff solenoid or valve parts, weak pressure regulator or worn fuel pump.
    tallmon and KeithT1967 Thank this.
  5. tallmon
    657
    319
    Oct 22, 2014
    OK. Will replace filters this weekend
    Thanks
  6. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    That pretty much confirms my theory of why the warning only shows up after ive been above 1500 rpm. Thanx hd
  7. Heavyd
    7,751
    6,184
    Feb 4, 2009
    Yep, filters first, both if you have two. Then after that I would remove and check the shutoff solenoid valve pieces for wear or sticking.
  8. tallmon
    657
    319
    Oct 22, 2014
    Fuel filters replaced yesterday. No codes so far today.
    Usually I know to change them by the fuel pressure but this time the pressure was fine and we got the code instead.
    Fingers crossed.
  9. ANTS Manager
    ANTS Manager Bobtail Member
    I have a Glider with a Detroit and it started this the day I had it serviced and all new filters installed.
