Cummins ISX 485 While Coolant smelling exhaust smoke
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, Mar 27, 2020.
  1. ichudov
    ichudov Medium Load Member
    667
    534
    Mar 14, 2012
    Berkeley, IL
    So I bought this truck with a Cummins ISX 485.
    Turns out that it emits copious amounts of white smoke which smells of coolant:
    However, I noticed that it only seems to do it at idle, if I push the gas pedal hard, the smoke disappears temporarily.
    I first suspected blown head gasket. After some thinking, I started suspecting that perhaps this is a leaking EGR cooler, since EGR is used when the engine is not loaded? Any thoughts?
    Thanks!
  2. Snailexpress
    1,784
    2,878
    Apr 28, 2014
    Disconnect corrugated pipe from exhaust to EGR cooler and start engine. If coolant from exhaust it's head. If it's dry you need new EGR cooler.
    ichudov Thanks this.
  3. ichudov
    667
    534
    Mar 14, 2012
    Berkeley, IL
    This is a really smart idea, I will do it!
  4. ichudov
    667
    534
    Mar 14, 2012
    Berkeley, IL
    Here's something interesting. I added some coolant and water today just to be on the level. Started the truck.
    To my surprise, the truck started and did NOT emit any white smoke!
    I could run it for a bit longer, but I have a feeling that it starts smoking only after it gets WARM. Anything that can be gleaned from this?
  • Draft saved Draft deleted
