Cummins isx air pressure in cooling system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kabusheke2004, Oct 1, 2016.
  1. kabusheke2004
    kabusheke2004 Light Load Member
    99
    36
    Jul 20, 2014
    Virginia
    Hello all.
    I have a 2006 Volvo VNL with a Cummins ISX engine. The egr is deleted.
    Lately i have been getting a STOP engine light driving down the road for critically low coolant level.
    I go to the coolant tank and all the coolant has shifted to the left side(reservoir).
    I open the black top cap and there is pressure in the tank. The coolant levels out after i let the pressure out.
    I had an oil sample today at Speedco to check for coolant in the oil caused by Head Gasket. Oil Sample came back clean.
    Does not overheat, normal oil temp, no power loss, no white smoke in the stacks.
    Coolant tank is turning darkish with gummy residue in the walls
    If anyone may have an idea what it could be i will appreciate any advice.
    Thanks and be safe
  3. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    If it's not the head gasket then it's more than likely the air compressor. go to a shop that can check the amount of pressure in your reservoir and then disable the compressor. plug the inlet air pipe and open both air tanks to relieve air pressure and see if your cooking system pressure drops.
    Don't trust speedco. get a mechanic to test the coolant system for compression or buy a kit from Napa for like 20 bucks.
    if there is a vent/overflow tube on the reservoir, make sure it's clean.
    the very cheapest option is that your reservoir cap is bad. they are pressure relief.
    AModelCat and kabusheke2004 Thank this.
  4. kabusheke2004
    99
    36
    Jul 20, 2014
    Virginia
    Thanks. Going to the shop on Monday
  5. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    If your truck has been d3l3ted, then its either the compressor, head or head gasket. Depending on the mileage of the engine, if the gasket failed, its highly recommended to check liner protrusion, Cummins ISX are known for sunk liners causing head gasket issues. My hunch is your having head/head gasket issues, if the coolant reservoir is getting darker, normally its an indication of combustion gases in the cooling system, there's a test with liquid and vacuum pump that can be used to confirm combustion gases being present in the system, if the fluid changes color, then start pulling the head. Do you have the horsepower/torque cranked up too?
  6. kabusheke2004
    99
    36
    Jul 20, 2014
    Virginia
    Ye the HP is up. It has 300k on an inframe. The previous owner had a used head put in it.will get the coolant tested for combustion gases. Thanks
  7. Intact Transport
    Intact Transport Bobtail Member
    I have this same problem with mine and my air compressor secondary air drops while I'm driving. So what does the air compressor have to do with The cooling system.
  8. cumminskid123
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    coolant runs through the air compressor head, if the compressor head cracks, air pressure is much greater than cooling system pressure which is max. 15 psi, and so it would pressurize the cooling system, if your truck doesn't hold air overnight...I've also seen cases where coolant will seep into the compressed air system when truck air pressure gets low enough, and you'll have some coolant in your wet tank. All depends on the nature of the failure. EGR coolers, cylinder heads and head gaskets can fail and pressurize your cooling system with combustion gases. There is a tester available with a liquid that changes color at the detection of combustion gases, if the blue fluid turns yellow(that's what my tester does) then it has detected combustion, if not, then i would pursue the compressor
    AModelCat Thanks this.
  9. cumminskid123
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    What was the outcome of your combustion test? What did you end up doing for a fix?
  10. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    With a residue on coolant tank walls it could also be and oil cooler beginning to fail
  11. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    The last truck I used compression gas tester on picked up nothing. Just to be safe I bypassed the air compressor and was still getting coolant pushing out. Removed the head and the liners had sunk. The engine before that when I did the test I got immediate color change on tester fluid. Pulled that head off and it was cracked and had blown gasket in two spots. The compression gas tester is a good tool but I have found it to be inaccurate at times.
    cumminskid123 Thanks this.
