Cummins isx air pressure in cooling system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kabusheke2004, Oct 1, 2016.
  1. Jamisoner
    Jamisoner Bobtail Member
    Where do you get this tester and what do you call it?
  3. Jamisoner
    Is it possible that the egr could still cause a problem even after it's been deleted?
  4. Truckers Report Jobs
  5. RdWilcox
    RdWilcox Bobtail Member
    I have a 2014 Pete 579 w/ Cummins ISX 15 (450 HP). It fills up the reservoir and has no pressure on it, I have changed the reservoir recently, even hot no pressure.
  6. Dexx69
    Dexx69 Bobtail Member
    28
    5
    Mar 14, 2012
    Swanton,vt
    I've got a '13 isx that pushes coolant (maybe a quart at a time) only when I pull into a customer after a long haul (Bordentown,nj-Boston). We've done the bottle test, put a pressure gauge on res and ran the truck @ 1000 rpms for a couple hours it only built 14-15 psi. Engine has been d3l3t3d, but still has the vg turbo.. . We've also replaced the compressor less than 2 weeks ago with a new cummins compressor..this has the shop and I scratching our heads, because you'd think it'd push it out all the time, or it'd be worse pulling a heavy load up a hill but it doesn't...
  7. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    What model and year of truck is it in?
    Oxbow Thanks this.
  8. Deeee
    Deeee Bobtail Member
    I have a 12 Isx that’s is filling the coolant reservoir up with oil. When the engine is idling it’s pushing oil out the bypass hole but when you raise the rpm it stops. I’ve looked everywhere for answers and still can’t find what it could be either it’s a crack head, head gasket, or maybe the air compressor. I changed the oil cooler 2 weeks ago because of the same problem but it wasn’t pressurizing my coolant system. I’m open to any suggestions that will help figure out my problem.
