Cummins isx cm570 leak between compressor and power steering pump
Discussion in 'International Forum' started by vicdsm, Nov 16, 2018.
  1. vicdsm
    vicdsm Bobtail Member
    28
    8
    Mar 10, 2009
    new york
    After reading alot of post, notice when these compressors leak oil is usually into air tanks..
    My issue is engine oil leak between compressor and power steering pump.. I bled power steering and put the clear dealer stuff. So the resvoir oil is not engine oil and also can tell by the smell of the oil.. also has knocking sound that goes away when the "excess" air dumps once air is built up.. or turning the steering wheel will change tone of the sound.. btw the power steering pump is new ..
    Why is there a gasket in between , is there suppose to be oil between pump and compressor for the shaft or smtg??...
    Builds up air good just don't know if oil is suppose to come out even if there was no power steering pump behind compressor. "Mechanics" around here (where I live) can't give me an answer even after replacing the gasket again between compressor and pump if it's the compressor from inside or.smtg. thanks in advance for any input .
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    I agree, there really should be a rear seal there, but I guess they are just trying to keep it simple and rely on the gasket only.
