cummins isx fault code
Discussion in 'International Forum' started by gjr2525, Feb 10, 2014.
  1. gjr2525
    gjr2525 Bobtail Member
    fl
    i have a 04 9400i, with cummins isx, small shop showed fault code #95 fuelfilter diff pres, any ideas, thnks
  3. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Double check that code number, no such thing.
  4. gjr2525
    fl
    i thought that might be wrong but i seen it on his meter and he said to check on line and i couldnt find sny thing like it, so will have to come up with something else, thnks for reply
  5. Heavyd
    7,811
    6,264
    Feb 4, 2009
    Most generic code readers only display in SAE format which is kinda more of a car OBD thing. With trucks it is very different. Each manufacture has their own set of fault codes which require software for each of those manufactures. The software program for Cummins is called Insite. Other scan tools can read the codes, but often there are errors in the translation between manufacture codes and SAE format.
