Cummins isx motor uses 1 gal.of antifreeze a day
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by trenten02, Oct 11, 2024.
  1. trenten02
    trenten02 Bobtail Member
    20
    Apr 21, 2011
    monroe,wi
    2016 international with cummins isx is using 1 gal.a day and don't see any leaks..truck seems to run fine.no water in oil..no smoking..trucks been deleted..could it be something beside liner or head gasket?
  3. RollinChaos
    RollinChaos Light Load Member
    155
    261
    Oct 6, 2024
    North Carolina
  4. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Are you asking me or you think that's what it could be?
  5. RollinChaos
    155
    261
    Oct 6, 2024
    North Carolina
    Charge Air Cooler could be leaking.
    At least that is what someone told me when I was having trouble with an ISX 15 leaking coolant. In my case it was a slow steady steam from bottom of radiator.
    Has a shop done a pressure test to try and identify any leaks?
    If the rig is not driven or only short rides is the lost coolant any less?
  6. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Look inside your fuel tanks and check for coolant at the bottom.
    wore out and blairandgretchen Thank this.
  7. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Don't see anything in the fuel tank.. I did.
    Take the radiator cap off And there's very little pressure
  8. Heavyd
    7,773
    6,211
    Feb 4, 2009
    Pressure test your cooling system and check for leaks. Looking at the engine from underneath is a great way to find pesky leaks as gravity will pull it down. They aren't always in plain view from the side. Sometimes the leak drips onto hot exhaust parts such as the manifold and instantly burnt and evaporated away. Air compressors can drink coolant, check for coolant at the air dryer purge valve or tank drain valve. Also check the sleeper HVAC heater core for leaking. They like to leak down the side and will soak in the insulation in the cargo bay under the bunk and will hold a couple of jugs worth believe it or not.
  9. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    Step One. Pressure test the cooling system.
  10. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Yeah, with no pressure when taking the cap off.It's almost got to be a leak.. Hopefully rules out a head gasket or liner anyway.. It's been deleted, but I see the e.G.R cooler is still on there.Maybe that could be the problem
  11. AModelCat
    159,170
    Charge air cooler has zero to do with coolant. Its an air to air heat exchanger.
    35+ years ago they used JWAC, which used engine coolant to cool the boosted air but I don't believe those are widely used anymore.
