Cummins isx oil in water/coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by adistoe82, Nov 12, 2009.
  1. adistoe82
    adistoe82 Bobtail Member
    Detroit, MI
    Hi,
    I have a 2003 Volvo 770 with Cummins ISX 450HP engine 860K miles. A few months ago I nottice that my coolant exapansion tank is turning a little black inside and I though it's just gunk from the engine running hot during summer with heavy load in California.
    A few days ago I pulled the coolant filter out and surprize, a few drops of oil inside. In the past few moths I did 2-3 oil analisys and everything was great, no coolant in oil. Oil pressure it's ok, water temp ok, coolant level with engine cold about 1/2 of tank with engine hot full tank and some coolant in the left side of tank. There are no air bubbles in the expansion tank. No white/blue smoke, nothing besides soma blackness in the coolant tank.
    Does anybody know how this small amount of oil got into my coolant???
    Thank you.
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    Oil cooler housing to block gasket. They were bad for minor seepage. Where the oil leaves the filter head and goes to the block through about a 1" diameter hole the gasket seeps right there. All around the pass through is the coolant jacket. When the engine cools down the metal contract and oil seeps through to the coolant. Once warm and the metal expands again it makes a good seal, that is why the leak into the coolant is so slow. Not that bad of a job, turbo has to come off. Turbo studs and nuts probably all rusted and seized, that would be worst part. Not sure how great the access would be on a volvo, but I would guess around 6 hours labor.
  4. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    i had the same problem and it was my oil cooler
  5. vegetto
    vegetto Bobtail Member
    20
    5
    Dec 14, 2006
    for an oil cooler, it would be about 10 hours labor...maybe a bit cheaper since on a 770. that is one hell of a bill i know, especially since my shop charges 110/hr
  6. adistoe82
    Detroit, MI
    I just got my truck out from the Volvo dealer and they found a bad oil cooler. The bill was almost 2000 but I had everything replaced, coolant, coolant filter, oil cooler, expansion tank and two flushes. Thank you all for your answers.
  7. Kropp
    Kropp Bobtail Member
    ISX 450 cummins 2005 ........We have had the same Issue . We also had a large amount of oil missing and low coolant level in the expansion tank . With no smoke in the exhaust....... Any trouble shooting ideas ......
