Cummins ISX overheating and coolant issues??....
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Nov 26, 2018.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    hey guys,
    i have an '08 prostar with a cummins isx, im a die hard CAT man but this is our only unit with a cummins the rest are c13's and c15, it runs good on power but lately for the past two months its been heating up while idles, it gets to around 210 to 215 in around 20 mins however when its driving on the road its fine, the drivers had brought it back before this with engine overheat code twice as well as a coolant low code, it had an egr cooler leak, not internally but it was cracked on the outside brackets, we got it welded and we've checked inside numerous times after but there is no coolant, the truck does loose a little coolant occasionally, the doc and dpf have been cleaned, it was running freeflow bcs i took the thermostat so it wouldnt overheat even more but its winter now and the drivers need heat so i put it back in, recently i noticed on an exhaust leak around the outlet to the stack there is a white stain almost like sprayed out of it, as well a dripping sort of stain coming from the top of the stack, the fan works fine as well as the water pump, there are no bubbles in the reservoir to indicate head completely and the truck has fine power also no smoke from the stack as far i can see when it drives, we're planning on taking the exhaust manifold to take a look inside the cylinders for any coolant, i apologize for the lot of readin but im trying to give u guys everything it does, what do u think im lookin at here? head cracked, head gasket, sunk liner? anything else ? lemme know thanks guys
  3. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    First things first, check engine fan operation and that it cools from 220 to 180 in short order. You stated it's fine running down the road. You have little or no airflow while stationary.
    Combustion in the cooling system ussually gets worse and pushes coolant out overflow while driving due to overpressure. Rapid temp fluctuation and fan cycling is another clue to air or compression in the cooling system.
    I would also be replaced the thermostat with new. Especially if there is a chance it has been hot.
    BoxCarKidd and wtokhi Thank this.
  4. wtokhi
    251
    115
    Nov 3, 2017
    thx and yeah i get ya, i put a new thermostat in, and yes after it drives for a while u can see that coolant has come out of the cap and its under max so im not overfilling it, and we set the fan to kick on at 195 just to be safe
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    If you have a ProStar with an ISX then you have to go on Rawze.com.
    wtokhi Thanks this.
