Hey guys soo I have 2013 kw t660 with Cummins isx 15 cm2250 I recently got Dpf baked and cleaned on it. It kept doing a regen every 300 to 450 miles after that soo I changed I map sensor,delta p sensor,differential pressure sensor, injector dose, fixed 2 exhaust leaks, and did a regen has a buddy connect insite for numbers all the numbers looked good filter soot status was normal, now there's a filter full lamp lit on the dashboard if I unplug delta p sensor it goes away but as soon as I plug delta p back the light is back as well. Anybody know what's going on here even on insite there was 0 reading from delta p
Cummins isx15 cm-2250 filter full sign on
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbilt 386, Feb 11, 2020.
What are "numbers looked good" values? How long did it take for 7th injector to begin dosing? Any codes? Much more to look at during regen with Insite.
Wannabe tech, spsauerland and pushbroom Thank this. -
How many miles? Mines at Cummins right now. $8700
SCR being replaced, doser, basically overhaul of the aftertreatment system, several sensors.
I'm at 700K miles that's kinda when that stuff goes south if you've been careful.
Cummins is expensive, but you also get what you pay for. Consider taking it to a Cummins, not a dealer. You'll probably be dollars ahead in the end. -
Have you had the ceramic plungers in the fuel pump changed? That's a cheap swap, and necessary. -
