Buying a dump truck with a M11 never had a jake brake, does anyone know if a jake can be instslled and roughly how much would it cost.Thanks.
cummins m11, can you install a jake brake?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Feb 10, 2018.
Van der Haags shows $1200 for a used set.
Thanks but a cummins mechanic said I needed jake model # 404d but all I keep finding is the model # 411
411 is M11 and 404 is L10. Don't forget you will also need exhaust valve crosshead bridges, injector adjusting screws, riser housing, oil feed line and fittings/ clamps. Then you have to wire up control side.
Goodysnap Thanks this.
