Just picked up a 1999 freightliner with a 525hp N-14 Cummins, took it out today for the first time hauling fairly light load in over a couple passes. Just didn't seem to have the power it should. Other truck is a 475hp cat. Thought it would run better, is it driver error wrong rpm seems to pull better around around 1400-1500 or should I look into other mechanical issues or is it what it is???? Appreciate any advice.
Cummins N-14 power????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ecnal regnew, Jul 9, 2016.
I have one like yours only a year newer that I bought in January and it always has pulled like a mule , I cruise at 1500 to 1550 and downshift about 1300 .
Fuel mileage sucks ..never over 6...but I'm always heavy and my trailer grabs alot of wind .
Other than mpg I've been very happy with it . -
Does it have a boost gauge,if so what is it under a hard pull.You can tell a whole lot from that.Check air cleaner restriction,fuel filter also. Owned an N-14 500 for a long time,ran great.
First thing is to check maintenance items that affect performance, i.e. filters. Next is to verify the intake and fuel system doesn't have any issues like a torn CAC hose or cracked fuel line that is sucking air. After that is verified then you can dyno it and verify performance but don't compare it to another truck/engine combination unless everything is the same, you'll prejudice yourself and one or the other will never perform "right".
i've seen fuel pump drives being worn out on these. with lots of hours those ecm's can cause issues with wearing out injector driver transistors too, i'd check for proper fuel pressure first, 25 psi during cranking, 120 psi at 1200 rpm and 150 to 180 psi at governed rpm.
bzinger Thanks this. -
Thank you for all the info, sorry so late response, new air cleaners, boost is 28-30, look over all fuel supply lines all looks good but I did find our the fuel heater lines were not shut off would think that would make a difference? It also seems to idle a little rough and touch noisy. So injectors or valve adjustment?????????
Thanks againbzinger Thanks this. -
I Will also check the fuel pressure, the engine has paper of a complete Cummins overhaul around 260,000 miles ago
Yes,run the rack,easy to do,get that correct,so you have a starting point.My 95 N-14 500 would pull 37-38 psi of boost,depending on the atmosphere.Whenever my boost would start dropping,first thing I would do is change the fuel filter,99% of the time that was the problem.No fuel,no boost.
I changed an injector, which was working intermittently (somehow my mechanic spotted it), did valve adjustment and gained about 0.7 mpg. Heavy 6.5 mpg, under 20k about 7.5 mpg running 65-70 mph with dry van
