Cummins N14 boosting the power/filter vac #'s
Discussion in 'Trucks [ Eighteen Wheelers ]' started by zx150, Oct 16, 2016.
  1. zx150
    zx150 Medium Load Member
    343
    45
    Mar 30, 2012
    I have a 'new to me' truck with an N14 Cummins that is supposed to be built to 500HP but is in reality an absolute dog even with 30LBS of boost on the gauge. 300,000 miles on an out of frame which included new heads, turbo, injectors, fuel pump, manifolds etc with paperwork to prove it.
    I NEED to get more power out of this engine, as I am being passed by old overloaded Autocar dump trucks on the hills. What can be done to wake it up? It's a 91 Pete with the Cummins N14 Celect.
    Before I have somebody plug into the truck I'm curious how big of an effect would high #'s on the filter vacuum gauge have on performance? 10LBS vacuum at idle and 15-20 while driving. It spikes the highest while coasting, decelerating or using the jakes which pegs the needle.
    I've narrowed down the root cause of the high #'s to the fuel lines, somebody installed too narrow of a line between the tank and ECM cooler. The numbers are much lower(2LBS total) if I go direct from the filter to the tank.
    Working on getting new lines built and installing some sort of pre filter. On a total side note are the FASS systems worth it?
  3. bzinger
    bzinger Road Train Member
    16,605
    65,861
    Dec 10, 2014
    omaha , ne
    If I'm reading your post right I had same problem with my n14 525 red top along with lousy mpg .
    Tossed supposedly good air filters in trash and repaired leaky charge air cooler .
    High 30s boost pressure now and mpg in the 6s consistently driving at 65 or less ..somtimes pushes 7 .
  4. pigeon river trucking
    pigeon river trucking Light Load Member
    132
    99
    Jan 1, 2016
    michigan
    Definitely sounds like it needs air filters if it is reading that high.
    bzinger Thanks this.
  5. bzinger
    16,605
    65,861
    Dec 10, 2014
    omaha , ne
    I think your right...my restriction gauge was barely reading anything when I tossed the air filters and put in new ...mpg instantly went up 5/10s.
    pigeon river trucking Thanks this.
  6. zx150
    343
    45
    Mar 30, 2012
    I should have been a little more clear, the high #'s are on the fuel filter gauge. Air filter #'s are fine.
    For ####s and grins I'll replace the air filter to see if it improves anything, no clue how old it is anyway.
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Sounds about right.My 95 N-14 CPL1844 Red top 500,ran upper 30 psi boost,depending on the weather,but usually around 38psi.Never a power issue,engine ran like a clock.If my boost dropped,it was fuel filter time.
    zx150 Thanks this.
  8. pigeon river trucking
    132
    99
    Jan 1, 2016
    michigan
    Is it a fuel pressure gauge or a vacuum gauge?
  9. zx150
    343
    45
    Mar 30, 2012
    Fuel vacuum.
  10. colorado18spd
    colorado18spd Medium Load Member
    396
    297
    Mar 10, 2013
    Need to look at the check valve on the upper left on the cooling plate. Behind ECM
    ChevyCam and zx150 Thank this.
