Hi All
I have Cummins N14 Celect Plus - 14L - 1995 ish - cold idling rpm problem ( in a Freightliner FLB )
Engine starts and idles around 800rpm ( ish ) - then it appears when compressor turns off pressure alarm - or around that timing - rpm increaess to 1000 rpm and stays there - will not come back to the 800rpm. This would be around approx 5 minutes ( ish ) of idling.
I am guessing its a faulty sensor?
Anyone else had this problem?
Apart from that - engine appears to perform normally.
Truck has been sitting for quite a while - if that helps.
Thanking you in advance - any feedback would be appreciated.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kiwi Man, Nov 8, 2023.
What is idle set at? If it returns to lower RPM after warming up, i would think it's in the ECM programming for cold mode.
Honestly can't remember ever seeing a 14 with a cold start change in the parametersOxbow Thanks this. -
Hi and thanks - idling does not return at all - thats the problem - it stays at 1000rpm which makes it hard to get into gear etc.
At around 5 minutes of idling from cold - it slowly revs up to 1000rpm and stays there.
I have not read any codes yet - I doubt anyone would select 1000rpm for idle? -
Are you sure there's no interference with the throttle pedal? I would be hooking it up and look at throttle %
Throttle pedal remains untouched and it still rises to 1000 rpm with no apparent input or pedal movement.
Will do !!
This thing have a PTO?
Yes - for under body hoist - clutch engaged.
