Cummins N14 Celect Plus Derate Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SPCZippo, Sep 16, 2013.
  1. SPCZippo
    SPCZippo Bobtail Member
    Ok we have a 2000 KW W900 with the N14 Celect Plus engine, and its been giving us fits for a few months now. Hopefully some one here can point us in the right direction. I red the code and I think it was 433 but I could be wrong, I know that its derating the motor to idle only. and the Code description was Intake sensor sends high boost pressure signal when other sensors are sending a low boost pressure signal So Boost pressure MUST be low.(scanned with the cummins INSITE program) We have replaced both sensors in the intake system with new parts and still the code/problem remains. Is there a way to test if one of the intake sensors is bad? (like ohm it out or something?) My boss says that theirs a broken wire in the harness but if every plug tests at 12.5 + volts that cant be the issue right? Also some one said that an EGR issue can cause this but i want to know does the N14 have an EGR system?
    Thank you For Any Help
    Zippo
  3. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    The plugs may test at 12.5 volts, but what's important is how much of that voltage gets back to the computer. That's what it is looking for and the sensor is responsible for. I'd try to see if I could get an ECM that's set up as close as possible to the current unit.
  4. wore out
    wore out Numbered Classic
    15,382
    185,693
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If the plugs test at 12 volts theres a problem, ECM is supplied with 12volt but breaks it dowm to 5 volt, on a 3 wire sensor you typically will have you 5 volt reference, a grd, and a signal wire the signal wire measures in .1 volt increments to tell ecm the values at the sensor. I only use a DVOM when checking ecm voltage. Yes you can ohm sensors to see if they are bad, since you replaced them already I'm with the boss bad wire in harness. Cummins celect and celect plus are pretty notorious for wire insulation to look good but wire inside be broken a pin test will tell you
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Here is the trouble shooting steps for flash code 433
    Circuit Description
    The intake manifold pressure sensor monitors intake manifold pressure and passes information to the electronic control module (ECM) through the sensor harness. If intake manifold pressure becomes too high, it will cause a derate condition.
    Component Location
    The intake manifold pressure sensor is located on the air intake manifold. Refer to Procedure 100-002 (Engine Diagrams) in Section E for component location.
    Shop Talk
    • The ECM checks for this fault only at idle speed. If the intake manifold pressure shows too high of a value at this time, the ECM will log a fault code.
    • Using the intake manifold pressure sensor breakout cable, Part Number 3824775, between the intake manifold pressure sensor and the engine harness sensor connector, with keyswitch ON. Check with intake manifold pressure sensor connected and disconnected.
    • Run an Automated Cylinder Performance test and/or Single Cylinder Cutout test to detect an injector problem causing the fault. Look for alternate fuel sources, such as oil-filled charge air coolers or blown seals in the turbo causing this fault.
    [SIZE=+0]Cautions and Warnings[/SIZE]
    [TABLE="align: center"]
    [TR]
    [TD][​IMG] [SIZE=+2]CAUTION[/SIZE] [​IMG]
    To avoid pin and harness damage, use the following test leads when taking a measurement:
    Part Number 3822758 - male Deutsch/™AMP®/Metri-Pack™ test lead
    Part Number 3824775 - breakout cable
    Part Number 3824776 - breakout cable.
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    To avoid damaging a new ECM, all other active fault codes must be investigated prior to replacing the ECM.
    [/TD]
    [/TR]
    [/TABLE]
    Troubleshooting Steps
    [TABLE]
    [TR]
    [TH="bgcolor: #cccccc, colspan: 2, align: left"]STEPS
    [/TH]
    [TH="bgcolor: #cccccc, align: left"]SPECIFICATIONS
    [/TH]
    [/TR]
    [TR]
    [TD]STEP 1.
    [/TD]
    [TD="width: 40%"]Check the intake manifold pressure sensor.
    [/TD]
    [TD="width: 60%"][/TD]
    [/TR]
    [TR]
    [TD="width: 10%"][/TD]
    [TD]STEP 1A. Inspect the sensor circuit for tampering.
    [/TD]
    [TD]No tampering
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 1B. Inspect the harness and the sensor connector pins.
    [/TD]
    [TD]No damaged pins
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 1C. Read the fault codes.
    [/TD]
    [TD]Fault Code 433 is active
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 1D. Check the intake manifold pressure sensor supply voltage.
    [/TD]
    [TD]4.75 to 5.25-VDC
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 1D-1. Measure the voltage to the sensor.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STEP 1D-2. Measure the voltage from the ECM.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STEP 1E. Check the intake manifold pressure signal.
    [/TD]
    [TD]0.42 to 0.58-VDC
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 1E-1. Check for a short circuit from pin to pin.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STEP 1E-2. Check for continuity in sensor harness.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STEP 1E-3. Check for alternate fuel sources.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STEP 1E-4. Check for injectors out of specification.
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="width: 15%"]STEP 2.
    [/TD]
    [TD="width: 40%"]Check the sensor harness.
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 2A. Inspect the harness and the ECM connector pins.
    [/TD]
    [TD]No damaged pins
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 2B. Read the fault codes.
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 2C. Check for a short circuit from pin to pin.
    [/TD]
    [TD]More than 100k ohms
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 2D. Check for a short circuit to ground.
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 2E. Check for proper pin-to-pin wiring and continuity.
    [/TD]
    [TD]Less than 10 ohms
    [/TD]
    [/TR]
    [TR]
    [TD="width: 15%"]STEP 3.
    [/TD]
    [TD="width: 40%"]Clear the fault code.
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 3A. Disable the fault code.
    [/TD]
    [TD]Fault Code 433 inactive
    [/TD]
    [/TR]
    [TR]
    [TD]STEP 3B. Clear the inactive fault code.
    [/TD]
    [TD]All faults cleared
    [/TD]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1 - Check the intake manifold pressure sensor.
    [HR][/HR]
    Guided Step 1A - Inspect the sensor circuit for tampering.
    [TABLE]
    [TR]
    [TH="align: left"][TABLE]
    [TR]
    [TD]
    Conditions
    • Turn keyswitch OFF.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Check the intake manifold pressure sensor and the sensor harness for external wires or damaged harness braiding.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [TH="width: 50%, bgcolor: #cccccc, align: left"][/TH]
    [/TR]
    [TR]
    [TH="bgcolor: #006600, align: left"]OK
    [/TH]
    [TH="bgcolor: #990000, align: left"]NOT OK
    [/TH]
    [/TR]
    [TR]
    [TD]No tampering
    [/TD]
    [TD]Remove and record tampering. If tampering has occurred, repair the circuit, and record the tampering.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1B
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 3A
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][/TD]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1B - Inspect the harness and the sensor connector pins.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect the sensor harness from the intake manifold pressure sensor.
    • Flush and clean the connector pins, use electronic contact cleaner, Part Number 3824510.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Inspect the harness and the sensor connector pins for:
    • Loose connector
    • Corroded pins
    • Bent or broken pins
    • Pushed back or expanded pins
    • Moisture in or on the connector
    • Missing or damaged connector seals
    • Dirt or debris in or on the connector pins
    • Connector shell broken
    • Wire insulation damage
    • Damaged connector locking tab.
    For general inspection techniques, refer to Procedure 019-361 (Component Connector and Pin Inspection) in Section 19.[/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]No damaged pins
    [/TD]
    [TD]
    Repair the damaged pins. Repair or replace the engine harness, connector, or sensor, whichever has the damaged pins.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1C
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1C - Read the fault codes.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Connect all components.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Start the engine and let it idle for 1 minute.
    • Use Compulink™, Part Number 3823548, Echek™, Part Number 3824437, or INSITE™ electronic service tool, Part Number 3824638 to read the fault codes.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]Repair complete.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1D
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 3B
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1D - Check the intake manifold pressure sensor supply voltage.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect all pressure sensors from their connectors on the sensor harness, except the intake manifold pressure sensor.
    • Disconnect the coolant level sensor or shorting plug from its connector on the sensor harness.
    • Turn keyswitch ON.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Install the intake manifold pressure sensor breakout cable, Part Number 3824776, between the sensor and the sensor harness connector.
    • Measure the supply voltage from pin A to pin B of the breakout cable.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]Does not meet specifications.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1E
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1D-1
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1D-1 - Measure the voltage to the sensor.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect all pressure sensors from their connectors on the sensor harness.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Install the intake manifold pressure sensor breakout cable, Part Number 3824776, to the sensor harness connector.
    • Note: Do not connect the sensor to the breakout cable.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]4.75 to 5.25-VDC. Replace the intake manifold pressure sensor. Refer to Procedure 019-061 (Intake Manifold Pressure Sensor) in Section 19.
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1D-2
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1D-2 - Measure the voltage from the ECM.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Turn keyswitch “ON”.
    • Disconnect the sensor harness connector from the ECM.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Measure the voltage out of the ECM.
    • Measure the voltage from pin 2 to pin 13 of the ECM sensor port.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]4.75 to 5.25-VDC. Replace the engine harness. Refer to Procedure 019-043 (Engine Wiring Harness) in Section 19.
    [/TD]
    [TD]Replace the ECM and call for pre-authorization. Upon receipt of authorization, refer to Procedure 019-031 (Electronic Control Module (ECM)) in Section 19.
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1E - Check the intake manifold pressure signal.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect pin 26 of the sensor harness connector from the ECM.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Measure the signal voltage by installing the breakout cable's signal (pin C) and return (pin B) connectors into the multimeter.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1E-3
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1E-1
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1E-1 - Check for a short circuit from pin to pin.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Turn keyswitch “OFF”.
    • Disconnect all sensors and the CLS or shorting plug from their connectors.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Check for a short from pin to pin.
    • Measure the resistance from pin 2 of the sensor harness connector at the ECM to all other pins.
    • Measure the resistance from pin 13 of the sensor harness connector at the ECM to all other pins.
    • Measure the resistance from pin 26 of the sensor harness connector at the ECM to all other pins.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]
    Repair or replace the engine harness.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1E-2
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1E-2 - Check for continuity in sensor harness.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect the intake manifold pressure sensor from the engine harness.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Check for continuity in the sensor harness.
    • Measure the resistance from pin 2 of the sensor harness connector at the ECM to pin A of the sensor connector on the engine harness.
    • Measure the resistance from pin 13 of the sensor harness connector at the ECM to pin B of the sensor connector on the engine harness.
    • Measure the resistance from pin 26 of the sensor harness connector at the ECM to pin C of the sensor connector on the engine harness.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]
    Correct pin-to-pin wiring or open circuit. Repair or replace engine harness.
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1E-3 - Check for alternate fuel sources.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Check for alternate fuel sources. Look for alternate fuel sources creating extra boost:
    • charge air cooler filled with oil
    • blown or leaking turbo seals
    • ether bottles
    • sources external to engine, vapors, etc.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]No alternate sources
    [/TD]
    [TD]Remove alternate fuel sources.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1E-4
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 1E-4 - Check for injectors out of specification.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Connect electronic service tool.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Check injectors for compliance with specifications.
    • Run cylinder diagnostics with service tool.
    • Note: Depending on symptoms, different tests can be required. See guidelines for recommended diagnostics tests. If diagnostics are inconclusive, consider cylinders with higher exhaust temperatures or excessive smoke or fuel knock.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]Injectors within specifications
    [/TD]
    [TD]Proceed with troubleshooting conclusions from injector diagnostic testing.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 2A
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 2 - Check the sensor harness.
    [HR][/HR]
    Guided Step 2A - Inspect the harness and the ECM connector pins.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Inspect the harness and the ECM connector pins for:
    • Loose connector
    • Corroded pins
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]No damaged pins
    [/TD]
    [TD]
    Repair the damaged pins. Repair or replace the engine harness, connector, or ECM, whichever has the damaged pins.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 2B
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 2B - Read the fault codes.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [TD]Fault Codes 433 is active
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 2C
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 2C - Check for a short circuit from pin to pin.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect the sensor harness from all pressure sensors and the CLS or CLS shorting plug from harness.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Measure the resistance from pin 26 in the sensor harness connector to all other pins in the connector.
    • Measure the resistance from pin 13 in the sensor harness connector to all other pins in the connector.
    • Measure the resistance from pin 2 in the sensor harness connector to all other pins in the connector.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [TH="width: 50%, bgcolor: #cccccc, align: left"][TABLE]
    [TR]
    [TD][​IMG]
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 2D - Check for a short circuit to ground.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Measure the resistance from pin 26 in the sensor harness connector to the engine block ground.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 2E
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 2E - Check for proper wiring and continuity.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Disconnect sensor harness connector from ECM.
    • Disconnect intake manifold pressure sensor from sensor harness.
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    Check continuity of harness wiring.
    • Measure the resistance from pin 2 of the sensor harness connector to pin A of the sensor connector.
    • Measure the resistance from pin 13 of the sensor harness connector to pin B of the sensor connector.
    • Measure the resistance from pin 26 of the sensor harness connector to pin C of the sensor connector.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]
    Correct wiring or repair or replace harness.
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 3 - Clear the fault code.
    [HR][/HR]
    Guided Step 3A - Disable the fault code.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    • Connect all the components.
    • Connect INSITE™ electronic service tool,
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Use INSITE™ electronic service tool to verify Fault code 433 is inactive.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]Return to the troubleshooting steps, or contact a Cummins® Authorized Repair Location if all the steps have been completed and checked again.
    [/TD]
    [/TR]
    [TR]
    [/SIZE]
    [/TD]
    [TD="bgcolor: #cccccc"][SIZE=+0]Go to 1A
    [/SIZE]
    [/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [HR][/HR]
    Guided Step 3B - Clear the inactive fault code.
    [TABLE]
    [TR]
    [TR]
    [TD]
    Conditions
    [/TD]
    [/TR]
    [TR]
    [TD]
    Action
    • Use Compulink™, Part Number 3823549, Echek™, Part Number 3824437, or INSITE™ electronic service tool, Part Number 3824638 to clear the inactive fault codes.
    [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [/TH]
    [/TH]
    [/TR]
    [TR]
    [/TD]
    [TD]Troubleshoot any remaining active fault codes.
    [/TD]
    [/TR]
    [/TABLE]
  6. Turtles
    Turtles Light Load Member
    64
    49
    Jun 10, 2011
    Where did you get that manual? I've been looking for one.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    It from QuickServe online https://quickserve.cummins.com It's great for owner ops becasue it free for up to 5 ESN's. Repair shop need to pay a subscription for full access. Sign up and enter you engine serial # and you have access to all repair & parts info for up to 5 engines.
    It's also in the Insite help file if you have access to that.
    Heavyd Thanks this.
  8. SPCZippo
    Yea thats the thing We went through that whole process because we have the Insite program. But it never had me test continuity from the sensor to the harness on the3 ECU. So i will try that next, since these n14's have a problem with them sperating. But now What pins are what? the Insite program isn't very clear on that...
    Thanks For All The Help
    Zippo
  9. SPCZippo
    Ok so I ran a continuity test on all three of the wires and they all tested good. Then i ran a resistance test, and found some odd readings. If you hold the three prong plug with the latch at the top so that you have the two pins on the top and it looks like *.* I got .2 ohm on the top left pin 14.5 kOhm on the top right pin, and .2ohm on the bottom pin. What does this mean?
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    If you are testing ohms of each wire, from the sensor plug to the ECU with both disconnected, then 14.5k ohms mean high resistance and you have a problem in that wire to the ECU. Trace that wire and find the problem.
