cummins N14 has trouble starting
Discussion in 'Peterbilt Forum' started by gotasphalt, Mar 2, 2012.
  1. gotasphalt
    gotasphalt Bobtail Member
    grand junction colorado
    i have a 92 N14 that lately after being plugged in and warm just turns over and no fire. walk away for a while and it fires as though it was never shut down. any ideas?
  3. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    fuel related. solenoid sticking?
  4. gotasphalt
    somtimes with the key on, the post to the solenoid is hot and sometimes not. i replaced the solenoid recently
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Lets narrow this down a bit. Is this a problem only when you use the block heater? Once you get it running and warmed up, if you turn it off and right back on will it start? Do you turn on the heater b4 the second start? My guess if your block heater is over heating something fuel related.
    In my biodiesel days we had this problem on warm restarts (shut down engine while hot and restart 5 min later) It had to do with remaining methanol (a product used to make biodiesel) vapors getting over heated and doing something weird. We finaly determined it was extra unreacted methanol in the fuel and started better quality control to remove it. My guess is that there is maybe something in your diesel doing the same thing. Some winterize diesel with methanol. To much could be causing this. In our case the engines would start fine cold, and run fine. I'd recommend making sure your diesel isn't over winterized and try starting the engine a little colder.
  6. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    You said sometimes you get a hot too the fuel shut off solnoid and sometimes your not. If your not getting a hot there the truck will not start.:biggrin_25513:
