cummins n14 no start problem
Discussion in 'Volvo Forum' started by Mike_NC, Apr 26, 2012.
  1. Mike_NC
    Mike_NC Medium Load Member
    410
    199
    Aug 6, 2009
    North Carolina
    The engine will crank but will not fire. The fuse going to the ecm is blown and keeps blowing. Is the ecm shorting out? Need some advice, thanks.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    keep blowing at start up ore when you tirn ignition on? it is important.
    what fuse? in positive wire (in batery box?) ore negative wire near ECM?
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Could be bad solenoid. Unhook wire from solenoid and see if it blows fuse.
  5. Mike_NC
    410
    199
    Aug 6, 2009
    North Carolina
    It blows when the engine is being turned over, the fuse is at the ecm.
  6. Mike_NC
    410
    199
    Aug 6, 2009
    North Carolina
    Engine turns over just fine but will not fire, acts like it is out of fuel.
  7. Mike_NC
    410
    199
    Aug 6, 2009
    North Carolina
    Fuse in battery box is good.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it is bad engine grounding issue. Voltage drop on starter negative wire, fix it, till engine ecm is not damaged
  9. Mike_NC
    410
    199
    Aug 6, 2009
    North Carolina
    Update: Never could figure out why the ecm was blowing fuses, all wiring checked out along with pin connector checks for the injectors drivers. Ended up finding the fuel pump as only putting out 2-4 psi of pressure while turning the engine over. The metal drive gear behind the spider gear was really loose and the spline on the shaft were worn heavily. We assumed the gear was slipping.
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    exuse me
    bad NEGATIVE WIRE
