i have a '93 freightliner fld120 with a n14 and 9-speed.
question: what is the rpm range this engine works the best with this trans?
basically this is how i have been driving it:
when i start to pull a grade and the rpms begin to drop, i drop a gear at about 1400/1500, which causes the engine to turn at 1900/2000, so i back off a little so the engine stays at about 1800/1900. depending on the grade, i repeat this until i find the gear that lets me stay at about half throttle and the engine turning about 1700/1800 and i keep the boost in a range of 20-22psi. i dont have a pyro gauge so i want to keep the boost down and i never keep the throttle buried on the floor, i just grab a lower gear.
i hope i explained this well enough...
cummins n14 - rpm range
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joecitizen, Aug 24, 2010.
what all is involved in tuning up this engine?
ignorant on my part, 'cause not until the other day did i become aware a diesel could be tuned up. i am new to trucking and learning as fast as possible on how to properly maintain my truck. i dont want to be just another "steering wheel" holder, i want to know what is going on with the truck as much as reasonably possible.
thank you for your help... -
Valve and injector and jake brake lash settings, air, oil, fuel, gearbox/transmission filter, and coolant filter while your at it, besides this maybe a ECM check/update as required. and maybe also a engine oil flush treatment.Hope this helps a bit, regards Dave
Yes. Adjusting the valves, injectors and jake would be considered a tune up or so called overhead set.
What is your N-14 rated at for hp and torque?
Depending upon this, I think this engine's sweet spot is propobly going to be around 1500 to 1600 rpm. Of course everything depends on the hill, load, driver preference etc.
Sounds like you have a pretty good idea of what to do for a beginner! I think your definately in the right ball park.
I wouldn't be affraid to push that Cummins a little harder. Most electronic engines won't allow you to run too hot unless you run it mercilessly, or it has a hopped up program installed in it. Maybe try lugging it down a little more before you shift and see how that feels. If power/torque falls off sharply then you know you have gone too far.
It's basically all about driver preference and what works for you.
Hope this helps.
Floyd -
thanks for the replys...
i meant for my two different questions to be two different threads to avoid confusion, but alas, the powers that be combined them.
from the information i have gathered, the engine is 350 hp and i don't know the tq rating yet. -
my thoughts are you are dropping gears at too high a rpm. not that it will hurt, but it cost more fuel wise. if you drop a lower gear at 1300 instead of 1500-1600 & that brings you to a lower rpm, but NOT lugging engine, it would be better im my opinion. I have a detroit & never had experience with any other engine. I drop at 1300 & it will bring me to approx 1500-1600 rpm's. pulling a hill at 1600 is better than pulling at 1900. though my rpm's top out at 1850 so this works best for me. not sure if it is correct for your set up.
joecitizen Thanks this. -
Hmm...my N14 will boost up to about 36lbs sometimes, usually 33-34 though.
The redline and RPM at which advertized HP is reached is 2100 (on mine anyway). Figure it's probably good for a bit over that but not recommended. -
I recall a power spec sheet I got with my first N-14 in '93. As best I recall, torque peaked at 1200, hp peaked at 1600. But in the graph, they also included a fuel usage rate graph. I took a ruler and drew a line where torque was at peak, hp was near the peak, and fuel usage was at the lowest. It came in right at 1500 rpm. I operated the engine close either dead on that rpm or close to it on either side of that rpm, and I got darn good performance and decent fuel mileage out of it. I would usually grab a lower gear when it got down around 1300 and hardly ever took it above 1700, usually grabbing the next higher gear around 1600 except on a real hard pull I would go a little higher. She would just plain work great running around 1500 all day long.
you obviously have a newer N14... probably a red top rated around 500hp... way more than the 1 in questionhere
An N14 is a great engine and 1550 is the sweet spot max hp and torque, running above 1800 is just putting a lot of heat into the engine and burns a lot of fuel not much else.
I agree with everything else said, topping a hill you can take it below 1200, but 1300 to 1600 is the range you want to drive in.joecitizen Thanks this.
