Cummins oil change intervals and oil recommendation at 600k miles
Discussion in 'Experienced Truckers' Advice' started by Xenergiserx, Jun 20, 2022.
  1. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    The cummins I'm running now HATES that stuff.
    Increases oil consumption also.
    Rideandrepair and truckdriver31 Thank this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    My Cats all did over 6mpg at US weight. Even a 3406A.
  4. Rideandrepair
    17,338
    56,256
    Aug 8, 2015
    Only time I got 6, was the last few months I owned it. That was on flatland, with a 3000 lb. 900 mile turn. It had a 425C w/9 speed. I traded it for a 99 Classic 12.7, 13 speed. It got over 7, sometimes 8. Even higher a few times, doing the same run. Loaded heavy in the hills, after I’d put 400k on it. Average was 6.3. The 2000 Condo I have now, same specs, has always gotten less. I hit 7.8 last month running empty. It’s was only 300 miles. W/O any idling, driving easy, I topped it off at home just to see what’s possible. Weight, hills and wind definitely has a bigger effect on the Detroit’s.
    God prefers Diesels and kranky1 Thank this.
  5. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    I ran a 3406 CAT 475 Hp.
    Got around 6-6.5 mpg.
  6. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    Only way my Cummins will hit 6mpg is behind a tow truck.
  7. kranky1
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    I think I mentioned it to you before, but the two CM870’s my brokers are running needed a turbo change and a tune to be fit to keep. Both power and fuel. The tunes were a last act of desperation before they went out looking for a couple of Cats. No way to describe the difference it made in those engines. They’re both pretty happy with them now.
  8. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    Then you aren't driving it right or its geared very poorly.
    Rideandrepair Thanks this.
  9. Dave_in_AZ
    388,125
    Did my ISX at 20K along with all filters.
    Delvac 15-40 CK4 Mineral
    Sold at 750K never a problem. Still going strong at 900K+.
  10. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    I keep my foot to the floor wherever I go. If there's another way, I'm far too straight to figure it out.
    truckdriver31 Thanks this.
  11. unloader
    unloader Road Train Member
    1,037
    1,155
    Jan 7, 2013
    Y'all haul less than 10k loads or what? We do, and get it done as close to 25k as we can. Someone in your maintenance needs a talking to, because at heavy loads, you can't ride 50k per PM imo. #### is gonna break.
    unloader
