Cummins to cat swap questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NW can man, Mar 21, 2013.
  1. NW can man
    NW can man Light Load Member
    51
    9
    Apr 4, 2012
    Zillah WA
    Ok we are taking out the 600 cummins and putting in a C15 cat. What I'm trying to find out is do I need to do any rewiring? The motor I got has the complete wiring harness on it with all the end out of a 2003 Pete 379 and my truck in a 1999 Pete 379. According to my local peterbilt all I need to do is install my new motor and plug into the firewall and will be good to go but I wanted to hear what others have to say before I mess something up
    Thanks for any input.
  3. w900
    w900 Light Load Member
    83
    27
    Mar 25, 2009
    Carlisle,Pa
    I'm not positive, but I think you need to replace tps switch and harness to match. Hopefully somebody else will chime in to confirm
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    look at JYs. they sell wiring. You need engine interface wiring for your new engine. If it can tbe foiund - the only way is to purchase new connectors, termilasm wires and assemly wiring harness
  5. PETE97
    PETE97 Bobtail Member
    11
    Mar 16, 2012
    Sprindale,Wa
    Just did a similar swap in a 97 Pete last year....W900 is right new Tps.... ..as far as the harness goes I would reccomend getting ahold of Ed Mawk at Mawk Industries....some of the pins from the firewall connections could be in different places...not 100% positive...but I'm sure Ed Mawk could supply you with a schematic if needed....he built my harness and it plugged rite in with no issues....If it ain't a Cat its a Dog....hope this helps some...
    NW can man Thanks this.
  6. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    any plans for the Cummins ?
  7. NW can man
    51
    9
    Apr 4, 2012
    Zillah WA
    Not sure yet I may try parts it out unless i get a good offer. It has a turbo that is 6 months old, air compressor that is 5 months old, 1 new metering actuator and 1 new timing actuator ( each over 700 new) newer water pump, 2 new injectors.
    Serial # is 14000972 it is not motor that came in the truck it was a takeout that was rebuilt and installed in this truck
    The whole motor was rebuilt 1 year ago so all the pistons and sleeves should be good we just spun #4 rod bearing and the crank is shot. As you can tell it has been a very expensive motor for me the last year and I just like my cats alot better.
    If you are interested in it PM me a offer.
