Curiosity question......
Discussion in 'Questions From New Drivers' started by Commuter69, Mar 11, 2016.
  1. Commuter69
    Commuter69 Road Train Member
    1,134
    625
    Jul 2, 2014
    Of the 'real'(not fly by night, like my current employer) fleets out there, how old is the average truck / oldest truck before it is rotated out of service for company drivers? How old can an owner operator's truck be before the company intervenes, assuming the driver has been with the company for a while and maintenance/repairs are immaculate?
    This week, I literally got nothing accomplished after I left sacramento for the los angeles area on tuesday.. all was well and good with my 2007 freightliner until I reach the grapevine and start climbing.... then my engine starts to overheat so I call the company mechanic to inform him of the issue and I expected a solution by morning(I was just starting my 10). He calls me, has me try a couple of things(there are some things I can do mechanically, this not being one of them). He then suggests that I try to limp it back to sacramento.... I get rolling and not more than 10 miles later, I overheat again..... I am literally stopping every 10-15 miles to let it cool enough to run... the whole way from frazier park to buttonwillow. I get it diagnosed at buttonwillow where they find a hose that was shredded, and fixed it, or so I thought. The next morning, I continue south and experience more of the same and stop at wheeler ridge, where they find a faulty thermostat, but per the instructions of my company mechanic, they did not fix the problem, but didn't tell me, so I continue south and, you guessed it, I overheat again within 10 miles of climbing. It was then that the mechanic instructs me to return to sacramento, which I really didn't want to do in case the problem continued, it would take forever to go 300 miles if I had to stop every 10-15 like yesterday, I would run out of hours before arriving..... What I really wanted was either the truck fixed or a replacement brought to me to swap. Am I being unreasonable?
    By contrast, my school had a "beater" truck that only left the grounds for fuel. It did not get used on the street, forget about it being used at DMV for testing. It's only use was for skills on the yard and it was NEWER than this truck.... which is a 2007 with almost 1.1M miles.
    In the last 3 days, I drove just slightly more than a single 11 hour drive shift. Yesterday took the prize, I only drove 55 miles in 2.5 hours!
  3. Diesel Dave
    8,724
    25,001
    Jan 20, 2010
    Hesperia, Ca.
    One of the brokers I haul for have 96, 97, 99 Pete's with Cats. They run all over. They even have new ones 15, 16's. And in between. They prefer the older ones cause less trouble with emissions. So to answer your question, they have no rotation to pull them out of service. The older ones perform just as well as the new ones and better. I myself have a 94, in my avatar. I wouldn't hesitate to go anywhere with it.
    Toomanybikes and G13Tomcat Thank this.
  4. FloridaDriver
    FloridaDriver Bobtail Member
    41
    31
    Oct 25, 2015
    I drove for a company that had it's own garage. The floor was clean enough to eat off of. They issued me a truck that they knew had a transmission problem. In spite of bringing the problem I experienced to the shop's attention they would not fix it. It kept failing and failing and finally I gave it an unsafe inspection. They fired me. I complained to OSHA and after sticking to my story in-spite of them lying to OSHA they changed their tune and settled when OSHA told them they were doing an internal investigation. The point is what we would think is logical and reasonable doesn't mean someone else will. I drove for another company where the fan belts were being chewed up. One road call and three separate shop visits later they finally discovered (or re-discovered) the truck had been in a front end collision (before I got to the company) and the fan hub had bent. On that same truck after that air pressure kept draining as you drove down the road. It would cycle back up then repeat. Three separate shop visits for that problem and they had not found the culprit. Hopefully they will find and fix your truck problem.
  5. MidWest_MacDaddy
    11,180
    18,818
    Feb 21, 2015
    South Carolina
    The company I signed on with keep their trucks in the fleet for three years or so. I am a new driver and was assigned a 2013 Volvo with 535,000 miles on it. Then that one had some issues and they moved me to a similar 2014 Volvo. Both were awesome equipment and I enjoy driving both of them. I assume they are both about to be rotated out if the fleet.
  6. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Lots of companies keep only newer trucks 2-3 years old.
    But that doesn't mean much anymore.
    Guess there is a certain amount of luck involved.
    Some of the brand new trucks have problems from day one.
  7. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    Companies rotate trucks out on all sorts of different schedules. What does it really matter in the end what the “average” fleet might do?
    New trucks brake down just like older trucks do. Breakdowns are just part of the business so get used to it. Expecting them to bring out another truck to swap with when you have a break down is only going to leave you disappointed.
    HalpinUout Thanks this.
  8. unloader
    unloader Road Train Member
    1,037
    1,155
    Jan 7, 2013
    I drive for a mom and pop that has seven trucks I believe. We are leased on to a major specialized freight company. I believe all of our trucks are 2014 and newer.
    They just swapped me out of my truck and gave me a loaner because my door was hanging and my a/c wasn't working.
    So for any major issues I'd expect them to swap me out as well.
    On contrast I drove for a pallet yard one time that thought it was perfectly ok for me to roll with a drive wheel missing all but two lug nuts. They just couldn't understand why it wasn't safe because "the last guy ran on it for months!" and fought me tooth and nail to get them put back on.
    Getting things fixed and keeping them maintained is more about a companies culture than if the equipment is old or new.
    Also. Was that shredded hose something YOU could've caught had you popped the hood on a pre trip?
    unloader
    Dominick253 and ethos Thank this.
  9. Commuter69
    1,134
    625
    Jul 2, 2014
    Actually, no, it was shredded in a place where it was totally hidden from view, it even took the mechanic some time to find it...
  10. Naptown
    Naptown Road Train Member
    1,156
    2,983
    Oct 18, 2009
    Indiana
    The ltl company I work for keeps their trucks for about 9 years. Newer units go to linehaul, which packs the miles on fast. 1000 mi. or more in a 24 hr cycle. Older trucks are transferred to p&d. Lots of million mile trucks running the city, but they keep up on the maintenance pretty good.
  11. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    My truck is a 2007 and I would drive it anywhere. The condition of the truck means a lot more than the age. My motor has less than 200k miles on a complete rebuild and I think it is more reliable than a brand new one with all the emissions stuff to go haywire.
    Now if a truck is just old and neglected and wore out that is a different story.
